Jacking Points?
Where's the jacking points on our cars? I didn't see any that shouted out at me, so I just lifted from submember the other day? Is that ok? What about TV links? As for rear, is it ok to jack on the rear diff? Not something I'd normally do...
I am pretty sure you shouldn't jack on the rear diff due to the strain it puts on the rubber diff mounts, I stand to be corrected, but when I tried it I didn't like the amount of movement the diff did before it lifted the car
Rear diff is the subaru recommended point, and at the front there's a small metal cross member just after the under tray which is the lift point for the front end
Jacking points front and back ends side skirts 👍😃
Negative mate haha 👆🏻
Yeah that's the one I used, just wanted to be sure that was safe 🙈
Yep their definatly their.
Really? I didn't see them when I was looking 🙈😳
Both my front side skirt jackin points have been squashed and pushed up a bit at the front, I presume from someone using a trolley jack with no rubber on the lifting plate, so be careful how and with what you jack it up there
Yeah, that's what I'm using...mine has no rubber as well...
3 hours ago, aucky said:
Massively! Thanks! 😊😘
Oem jack on green.trolly on red in middle and axle stands go were green is also 😉
I jacked rear up today with diff, was a revelation !
Going to try this...did you use something on the jack to cushion it a bit? I tried to grab some foam from work but there wasn't any so I grabbed a few sticky pad things to put all over the plate...usually see people do it with wood...
 No mate, straight up...... bare ! 😂
I have an ice hockey puck type thing for my trolley jack with a groove cut out. Got it from flea bay about 8 quid or so...just the job
Just going to use a few old rags...still worries me haha
Have you got a link for one? I could do with one of those.
Evening all
Would a suitable jack point for my Classic be just beyond the sump, basically silverish metal part with the 2 bolts....see pic
Evening all
Yes you can use the trolly jack on that plate.
On 12/05/2017 at 5:23 AM, aucky said:
Thanks Aucky. What about the white circles?
