Afternoon all,
I've been having an issue with my car whilst getting it remapped. Brought the car two weeks ago tdo5 fitted, turbo back exhaust, 270lph fuel pump and piper cross panel fliter. When getting it remapped the car was loading with fuel and at the time the boost starts the fuel leans off. 12v at fuel pump, tried 2 fprs, fuel filter wasn't blocked. It's a year 2000 car so has yellow injectors. Any help would be great, thanks.
I had a similar problem turned out to be a cracked vac line under the fuel return hose by the turbo. As savage said probably unmetered air getting in after the maf. Smoke test?
Cheers guys gonna have a look at all the above mentioned. Thanks for the quick reply, appreciate it. 🖒
The fuel pumps brand new from lateral performance, also tried a maf less ecu still had an issue.
Standard, walbro 225 and another same problem.
I don't have any vacuum in my fuel tank either, no hiss when I remove filler cap. Please tell me if I'm being stupid.
The tank won't always hiss when you take the cap off
Sorry been so quiet was waiting on parts fuelab fpr changed turbo intake hose, y pipe (looked like a hairline crack) but whilst looking today I noticed a crack in my knock sensor.... could this be a culprit?
Right started to think camshaft sensor.....
Air/ fuel correction in row 2 is at 25% on a quick glance and without knowing anything else it looks bad, looks as tho it's trying to add 25% more fuel to the map
not sure as don't know the software or driving conditions
What you need to do if possible is log the air/fuel ratio all through the rev range and see where it's leaning out
Leaning out at around 4500rpm mate just popping and bucking only on anything over 1/2 throttle
May have been idle il check again in the morning
Definitely leaning at 4000-4500rpm under full throttle seems to be lumpy on whilst warming up but not when on idle
