whats the stock turbo for 1997 subaru impreza wrx
my turbo is a vf22 biggest of the wrx turbos, my cars is a standard wrx (not the wrx sti) dose that seem right to you guys?.....I dont think it is, to much bs when i google it
if it helps my 97 foz has a td04 as standard
I agree I thought TD04 was standard
Tdo4l iirc the turbo that's on yours ιs from the import uk model classic Sti wasn't ιt?
It was the one with all the confusion around it I remember. Log book said one thing sales guy said another :D
a mate of mine has a uk classic 99 plate with a vf22, my uk 97 has a td04 and i think the td05 is the import sti one, i was always of the belief that the vf was the same as the td but an after market buy as a replacement
Stolen from else where on the interwebs.
'Ok gonna clarify 96 did NOT use a VF 22 till after September when the Ver 3 came out with the EJ20k. The Version 2 still had a TD05Turbo and the only difference really between it and a Reg WRX was the ECU. To top it off the WRX came with the 22 while the STi came with the 23 hence alot of STi whooping going on. Also NO GC8 came with a TD04 the GFs did but not the GCs'
ah yeh, mines a GF, i didn't know the wagons and saloons differed to be honest
Nope I didn't either. Nice find Stanton ;)
I wouldn't take it as gospel though, i've only robbed someone elses work which could be way out. It is the internet after all :-D
Hey if it's on the internet mate it's real. You wont believe how many people I've fallen out with on the Net, all of them MMA fighters 6ft 2" cost me loads of money paying them off :D
Haha i can imagine, they'll never cross over into the flatlands of lincs, scary in its self !
Forgot to add i pulled it off a yank site so could be different for euro spec
a point of note - I will find the reference with more detail but I have put it somewhere safe ... :rolleyes: (I know its in another thread on here when a similar question was asked along the lines of "been offered a TD05 do I buy it??"
The TD04 refers to one half of the turbo and would normally be followed by some further letters and numbers which identify the second part of the turbo build for example we have TD04's across many subaru models but the difference is in second part which sorts size and type of vanes / impellar which vary in size and shape giving different boost properties so the Fossie gets lots of nice low down grunt and the Impreza gets more up top.
Am i right in thinking there should be a build plaque on the side of the trubo somewhere denoting what it is ?
I dunno what i've got in regards to the last letters no low down grunt for me mine starts to build around 2.7k then goes mental around 3-4k.
Under normal town driving it never boosts. Only when driving like an idiot or over 80 on the m/way
:-D
ok so after realising I had kicked over a rock - probably much as you did yourself from google - I am now pretty sure the standard turbo on the 1997 WRX (not STI) was a TD04-13T
the WRX STI had a TD05H - 16G
I now need to find a way to collate all the info I have found into something that is manageable :wacko:
You are right - It is the same turbo on the 97 Forester - there are different turbos on later forester models but I havent found the specs for those yet to validate my earlier post.
When i get home i'm
... going to have a sandwich?
... going to watch 'in the night garden'?
... going to have a kip?
:D
When i get home i'm gonna have a poke around me turbo. Ten quid says the info i need is on the bottom or back where you can't see it any way.
Haha stupid phone !
More interweb fishing is that its a td04L we shall see later. I'm not gonna pull everything apart tonight m.o.t 1st thing thurs. Still doesn't help kev lol
LMAO Kev's started something now :D
my turbo has the number embossed onto the casting, not sure if the VF's have it the same way
I'm fairly sure the version 1 &2 wrx's and sti's ran a tdo5 16 g (power difference was created by the map and intercooler flowing better ) im unsure what the early uk's run but my v3 uk came with a tdo4 as standard.
vf series turbos came in on version 3 and above sti's.
Where as the v3 and above uk turbo's and (i think also) wrx's ran tdo4's .
I do know the main differences between the vf's and tdo series though.
Tdo series are a journal based turbo's ( basically shaft through the middle which is lubed with oil by centralfrugal force ) they can take more abuse and can be easily rebuilt .
Where as the vf series have roller bearings which spool slightly quicker but don't tend to handle to much abuse and can't be rebuilt (as easily)
Cheers Savage I'm going with what you say I've seen what you can do :D
  • 3 years later...
my is a 1997jdm wrx,i has a vf22 turbo and yellow injectors an IS ecu now im confused........is my not standard then??
