Multiple Subaru parts needed
Dear Sir/Mam,
We are looking for parts for a
Subaru Impreza 4WD standard of WRX, preference goes out to a WRX (NO STI !!).
Construction year must be from 2002 untill 2007.
We are also capable to buy complete damaged cars.
We would like to have information (construction year, type, miles etc.) and pricing of the parts that are listed below (if you have them)
• Front spindles with full brakes and front lower control arms
• Rear spindles with brakes and e-brake handle/cables
• Steering rack, tie rod ends, and upper steering column assembly
• Pedal box and throttle pedal
• Master cylinder and brake booster, and clutch master cylinder
• Engine with turbo and intercooler (if WRX model)
• Exhaust manifolds, O2 sensors, and down tube
• Transmission
• Rear lower control arms, toe links, and CV joints
• Front seats, front seat belts, and gauge pod
• Fuel pump
• Radiator
• Wheels and tires
• Door hinges, rear w/ latches,strikers, and inside door handles
• Side view mirrors, left and right
• Rear view mirror
• Rear seat belts
• Rear Sway Bar
Thanks in advance,
Hammink Performance
I will Pin this for you if you like mate so it stays at the top.
And hows the builds going hope you guys have been busy :D
there is an 02 on ebay being broken, might be worth a shout. or give martin a ring a SSS he usually has or knows where there is parts.
  • 1 year later...
On ‎14‎/‎02‎/‎2014 at 8:20 AM, Hammink Performance said:
thanks for the help guys, and keep those replies coming
Hi,
Not sure if your still after parts but I have a load available, the added link is for my original post, I have pics of parts if you want them
Cheers
gnash
http://uk.subaruownersclub.com/forums/topic/13845-bugeye-wagon-bits-for-sale/#comment-84669
