Gauges
from the sandwich plate yes. What Stanton is saying you can get one gauge that will do the two things you want i.e the boost and the oil pressure
http://www.ebay.co.uk/itm/DEPO-racing-60-mm-Smoked-Oil-Pressure-Volt-Oil-Temp-and-Water-Temp-Multi-Gauge-/300864273970?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item460ce87e32
Like this as an example can do water and oil temp and pressure plus volts so it's a 4 in 1.
Get ya. Gonna go separate as gettin pillar pod with 2 holes. Poss gonna look into one to do oil pressure and temp. Where is best to get one at good price??
Personal preference would be my advice get what you like the look of. I think everyone will recommend to the ones they have like me with mine here ;)
But I would have a look and see which ones you like the look of
I'm still debating weather to move mine onto steering column.
I took mine off there didn't like it. Now have a carbon fiber effect pod so I look well hard ;)
And fitted now? [emoji16]
Sent from my SM-T210 using Tapatalk
Yeah it's fitted now :)
Right the gauges have arrived n today is day of fitting hopefully. I'm installing them in a pillar pod. How long does the pipe need to be for the boost gauge? It's a mechanical one. Cheers.
5 feet will be plenty, route it then chop back what you don't need. Nothing worse than coming up short.
It will need to go from roughly manifold towards strut tower avoiding turbo, down the back of the firewall, and through, theres a rubber bung half way down, push a skewer through it, if you lift the mat out of the drivers side and look at the pedals the it should be poking through :-) then up the back of dash to pillar
How did you get on ?
Went well. Not gt oil pressure hooked up yet but the boost gauge is working all looks smart and works. Not sure how to upload a photo from my phone to on here to show ya tho. If ya tell me how to post pic from my phone I'll post one
Just tried registering n it ain't working at the moment. So I'll try again tomo an try n get some pix up.
Looks good mate looks like my set up, same pod too :D
Cheers. N pod was £35 on eBay which is pretty good I think. I'll get a pic of then lit up wen it's dark later
