need advice
since i got my wrx the temp gauge got hotter and hotter but last nite it went to its all time high to just under red i checked the water bottle by the rad and it was ok but looked at the other coolant bottle and the water inside it was a rusty colour ive only done 118 miles since ive bought it last week ive head the oil for mayo but there was none looked at the exhaust or any excess steam but it seemed ok
Thermostat or trapped air in the hoses. Let it go cold, open up the top reservoir and squeeze some of the hoses to see if any air bubbles up.
looked at the enigne on sunday and the expansion tank water was a rusty colour i guess thats not good
Check on your fingers for rust particles,i thought my system was the same and it was the orange OAT coolant,nice in the bottle,but looks rusty or if drips onto any surface again rusty orange.....................not the best of colours imo...
Only a thought regarding rust.
If its recently had the system drained to replace the thermostat it's more likely an air lock.
If there's no mayo in the water it's doubtful it's the head gasket.
The scoob is notorious for getting airlocks, so I reckon this is the most likley cause.
Drain and refill the system and I reckon that will cure it.
ive not replaced it yet ive bought one and awaiting for it to arrive
Stick your nose in the overflow and smell for exhaust/petrol smell. Also check the overflow for bubbles while the car is running. That may indicate hg. There's also a sniff test a garage can do for you to detect hydro carbons.
what one is the overflow the one by the rad or the other near the intercooler
The rust could be where it's been filled with to much water to coolant ratio and has started to rust the inside , thermostat might not be opening or air lock ,they are absolute !Removed! for air locks , but I have a good way of getting the air out :-)
will do that at the weekend
how do you get the air lock out nevell
did you get this from a dealer? take it back for them to fix ?
yeah if the coolant is old it looks like rusty water
whip thermostat out, boil kettle
put it in a jug, pour water over it and if it doesnt spring open then its knackered
yeah thats what my dad said lol but ive got one on its way but been waiting a while now i bought it on the 7th from scoobyworld
I'd get a hydrocarbon sniff test done at a different reputable garage to rule out combustion gasses in the coolant before working on it yourself , as they might say that you voided the warranty .
if the head gaskets have gone it's going to cost a fair bit and the garage should be paying for it so soon after purchase
STi lump time!
£££ lol
Is this car on eBay mate ?,
