Tidgy's project Type R
Nice shame about more damage being found but least not stopped the excitement [emoji3]
  • Replies 172
  • Views 34.2k
  • Small update today, look whats back from machine shop :D   followed by a normal block vs closed deck converted
  • Managed to get back up again with my camera so got some pics of the damage,     All 8 bearing halves have been worn down to copper and most have a deep ware grove in them middle of the bearing.
Yeah best way I was the same when mine was in being done.
Came across the origional graphs so thought i'd post them up.
this was the day i picked it up and it had gone straight up for a check over,
then after the syvecs, manifold, decat etc
and to compare,
was some gain in spool and peak but considerably lower than expected given the mods. and then the dreaded was found
Nice big difference [emoji106]
Popped up to clinic today top drop the mrs car off and check up on mine and how things are looking for next week. Found a few more bits that were worn out, inlet pipe is fooked so a new perrin one is going on, valve shims and buckets all had to be replaced so now got a set of supertech buckets and shims.
But end result is good news, heads are built and attached onto block, final checks on them to make sure all good and then cam covers will go on and rest of the engine can be assembled.
nice repainted inlet manifold
and then a rats nest of wires to go back on lol
Gearbox is done (5th gear syncro was worn) and ready to go back in, cars booked into the main workshop to have the engine and box fitted tuesday, few other bits and bobs before going off for mot and all being well next sat will be the day :D
warning, kid at christmas mode on!!!!!!!
hahahaha
not as big as expected tbh, but writing was on the wall. shall be interesting to see what it does when its back, run in and mapped up
me to :D
Ooh go steady will you be able to hand the power ?
What running period have you got 1k miles ?
yeah, not picked it up yet, having its mot tomorrow.
got 500 miles on crappy mineral oil, then 500 on semi synth all with no boost :(
then back for fully synth and map :D
Nice one mate glad to hear it [emoji106] 3000k miles to do is it now.
Oh right not to bad then [emoji3] soon do that after a few trips to fetch milk the long way round from the shop's [emoji106]
im already planning milage hahaha
work and back is about 30 miles if i go the long way/back country route. clinic and back is 60, im off to raf scampton sat which is 90,,,,,,,,, hahahaha
Not far from me Scampton [emoji3] and I like how you've even added the trip to and from the clinic lol. Only downside is this is where you have every nut sack in audi a3 and corsa up your !Removed! [emoji17] but be worth it [emoji106]
yeah, i saw you we in the broad sort of area around there lol
haha, yeah but it can wait lol
i need a sign saying 'running in, try again next week' lol
