Which Injectors do i need????
So I'm going to scooby clinic for a alcatek ECU fitted and mapped and while I'm there I'm upgrading my injectors they are standard at the moment and I've bee told to get yellow 440's. Scooby clinic are charging me 400 quid plus vat to supply and fit new injectors so am i better off buying some second hand ones or paying for new?
So when i come to buying second hand yellows is there just the one kind? just want to be certain i turn up with the right injectors to be fitted before the mapping
Ive got a WRX classic 94
3.5 inch exhaust
front mounted intercooler
new spark plugs
AEM induction kit
Standard turbo
RCM fuel pump
Am i right to be expecting 300 BHP?
yes it is TD05 , Brilliant!
Any ideas on the injectors ?
Unfortunately I can't say which injectors to go for. It's a bit beyond my knowledge. As for second hand units, it's always a risk because you don't want one failed when giving it some beans.
Phase 1/1.5 440's are a direct fit but they're getting on a bit and can't be resized (opened and reflowed to make them a bigger cc)
Phase 2 440's will fit with "phase adapters" in place (which cost about £ 50) .
Cheapest option would probably be good second hand ones off a trusted seller £40 injectors + £50 phase adapters including new O rings
Or get the above, then send the second hand phase 2 injectors off to someone like "lateral performance" to get them cleaned /refurbed for about £150 or reflowed and cleaned (made into a bigger cc) for about £250 ish
If you want the tdo5 to run more than 1.2 bar you'll need a later map sensor to be "mapped in" when fitting the ecu and possibly a newage coil pack conversion.
As standard early classic map sensors only read up to 1.2 bar and the coil packs somtimes don't like the extra boost [emoji6]
If it's not broke .....upgrade it
  • 4 weeks later...
I have some sti blue 560s they should fit strait in and be good for over 360bhp drop me a pm if your interested
sorry mate would have got them but I've already got myself some yellows
