Knock sensor
lev1982
Hi guys. It seems never ending at mo. Right car was ticking over for roughly 30 minutes no issues. The eml came on. Diags are saying 22 knock sensor.
Does this mean the sensor is gone or the sensor has found a fault.
Sent from my SM-G920F using Tapatalk
9 hours ago, savage bulldogs said:
I couldn't tell you what normal knock levels are on a oe ecu as I'm running apexi fc and I think the scale is different.
That's what mines got reads 2 when cold then goes to 9/10 when  warm is that good?
As stants said you normally get higher knock from cold starts ,highest I've seen on mine is 11 during cold start .
When warm and under boost I've seen 38 knock but I'm running nearly 1.6 bar and noisy forged internals . So probably not the best comparison if your engine is standard
