Need help urgently
Youngy
As above I need to remove my down pipe iv taken the top two off but having trouble with the rest so is there anyone in the Gravesend/Dartford area that could help out coz I haven't got the proper tools anyway but I will pay who ever can help thanks
They are on there good and I haven't got the proper tools to do it that's why I asked for help coz I don't want to knacker the bolts coz at the mo they are not rounded off
I know they can be a real pig to remove just from an access point of view! However if you are having trouble and  you can't get them off with WD40 and a 14m spanner or socket then it's either heat them up with a torch (may be able to use them again if when cool) or use the Irwin bolt grips and get some more nuts from eBay, cheap as chips. It's not worth the effort to try and save the nuts imho, a pack of 5 M10 nuts cost less than £5 posted
http://www.ebay.co.uk/itm/FLANGED-TYPE-MANIFOLD-NUTS-M10-x-1-25P-TRI-LOC-SUITS-IMPORTS-HBN10-QTY-5-/201161915756?hash=item2ed62f3d6c
