Boost pipe diagram
As above I changed the boost pipes the other day but I think I put them back wrong because I have a manual boost controller but it doesn't boost more than 9 psi and Iv tried the pipes round the other way aswell so either the pipes are wrong or my controller has broke which would be bad timing so has anyone got a picture or a diagram of the pipe work from a uk 99 plate
I'll take a few pictures of mine tonight and load them up if no-one has done beforehand. I'd suggest putting it all back to stock first to rule out any real problem with the car. Those manual controllers have the knack of breaking and then reeking havoc causing damage.
Ghost to the rescue, [emoji14]
Stock 2 port set up
Stock 3 port set up
3port with mbc
Mine is the 2 pipe boost controller and by the looks of it my pipes are all correct donuts the controller itself,so time for another new one I think
I have a spare boost control bracket if you need it! Also ask me and I'll take a video of my boost lines on my v4 classic
What's the boost control bracket and cheers mate that would be really helpful thanks
