Youngy Posted October 12, 2016 Posted October 12, 2016 As above yesterday my car was running really nice with no issues but today I went to get it out the garden and it would only run for 5 seconds then cut out but it would start straight away but cut out again, but now I went to get it back into the garden and it wouldn't start at all so what are people's opinions coz it's got me puzzled thanks in advance
GeoffLeggy Posted October 13, 2016 Posted October 13, 2016 First thing Id check off is that I had juice in it! Sounds silly but...... Then if you can hear the fuel pump priming? See what cel result is as above.
Youngy Posted October 13, 2016 Author Posted October 13, 2016 I made sure there was fuel in there first,I put £7 in it and no the cel light isn't on and I can hear the pump when I first turn the key but I'm 95% sure it's fuel starvation
GeoffLeggy Posted October 13, 2016 Posted October 13, 2016 Would be my first thought. Check no connections have come loose eg maf Suppose youd get light though?
kayzarh Posted October 13, 2016 Posted October 13, 2016 Hold up I'll post the good **** in 2 minutes Sent from my MX4 Pro using Tapatalk
kayzarh Posted October 13, 2016 Posted October 13, 2016 Id say check your crank cam sensors and then check for spark. both the cam and crank sensors, no need to remove anything, just use some agility and test it with a multimeter in ohms mode. Camshaft sensor is here; Crank sensor is here ; Camshaft real life: Crank sensor real life: 1
Mr B Posted October 13, 2016 Posted October 13, 2016 ^ Sounds likely pump will initial prime with ignition on but will only power when engine cranking & reading the sensors for this, if sensors test ok check wiring connector harness . Review immobilizer circuit too as many (pending how wired in) cut pump trigger but not the prime trigger & had a few cars over years with sticky/failed relays in immobilizer modules .
kayzarh Posted October 13, 2016 Posted October 13, 2016 Keep us filled in and we'll get to to bottom of it in no time Sent from my MX4 Pro using Tapatalk
kayzarh Posted October 13, 2016 Posted October 13, 2016 On 10/13/2016 at 7:49 AM, Mr B said: ^ Sounds likely pump will initial prime with ignition on but will only power when engine cranking & reading the sensors for this, if sensors test ok check wiring connector harness . Review immobilizer circuit too as many (pending how wired in) cut pump trigger but not the prime trigger & had a few cars over years with sticky/failed relays in immobilizer modules . Expand @Youngyill get the techniques posted for you as soon as you check the sensors are okay
Youngy Posted October 13, 2016 Author Posted October 13, 2016 Thanks for all that I will be checking them in a bit and I will post back soon
Youngy Posted October 13, 2016 Author Posted October 13, 2016 Right I checked both sensors and they are fine I also took the fuel pipes off the filter to make sure the pump is pumping and it is and I don't think it's the maf because it would start even if it was knackered because Iv left it off before, when turning it over it does want to start but it just don't so I haven't a clue what it could be
Beags Posted October 13, 2016 Posted October 13, 2016 Sounds like immobilizer as it tries to start but won't. Sent from my SM-G357FZ using Tapatalk
kayzarh Posted October 13, 2016 Posted October 13, 2016 Do you have Aftermarket or stock immobiliser? Have you done a spark test? Sent from my MX4 Pro using Tapatalk
Scoobyghost Posted October 13, 2016 Posted October 13, 2016 How did it run when it was running for those few seconds?
savage bulldogs Posted October 13, 2016 Posted October 13, 2016 When you start it then it stalls, will it start up straight away if you prime the pump again by turning the key back to 0 and turn the key to start it again ? Have you checked the vac line to the fuel pressure regulator ? As it might just be starting on the initial pump prime and surge in pressure. If the fpr is ok it does sound like something is cutting the "constant " power to the pump that it should have when running .
Youngy Posted October 13, 2016 Author Posted October 13, 2016 It has a stock alarm on it and it ran perfect just for those seconds but I haven't checked the vac line but it isn't staring at all anymore but I did take the fuel line off at the filter then turned the car over and it filled a bottle up within seconds so I don't think it's fuel related anymore
Youngy Posted October 13, 2016 Author Posted October 13, 2016 And it did start up straight away after cutting out but it did have to go to 0 position
savage bulldogs Posted October 13, 2016 Posted October 13, 2016 Have you got any codes on the ecu ? checked all relays and fuses both under the bonnet and under the drivers side kick panel . If you've been running it low on fuel did you take the fuel line off after the fuel filter or before (could the filter be blocked)
kayzarh Posted October 13, 2016 Posted October 13, 2016 ill do a little brainwaving tomorrow and try to post some ideas.
Youngy Posted October 14, 2016 Author Posted October 14, 2016 Iv checked all fuses and relays under bonnet but nowhere else and I took the fuel lines off both sides just incase but Iv been reading and I'm sure it's a immobiliser problem
kayzarh Posted October 14, 2016 Posted October 14, 2016 I'm sure someone here can help you do an immobiliser bypass but are you 100% sure it is that? Sent from my MX4 Pro using Tapatalk
savage bulldogs Posted October 14, 2016 Posted October 14, 2016 Did you check the fuse box behind the plastic trim next to the accelerator peddle?
