Vf35 turbo on wrx?
Hello I want extra power out of my subaru impreza wrx 03 that's currently running 288bhp fully decatted
Has anyone else fitted a vf35 turbo to a wrx? If so what are they like ? And what sort of power did you make
Sent from my SM-G928F using Tapatalk
Already have a walbro fuel pump , what are they like comparison to the td04
Bit laggier but got alot more top end basicly.
Td04 has great spool but won't see above 290 on one so if you want more power bigger turbo is a must. Few different options depending on budget and goals though.
Looking at a vf35 a sti up pipe and st pink injectors, along with my full decat hoping for around 320bhp is this achieveable?
Hopefully I will:)
I have seen a few vf35 with suppoorting mods on WRX's and they are 350 ish on dyno dynamics. Mines at 1.45 bard and pulls hard as feck! not RR'd mine though.
on an optimistic dyno maybe. a true 350 out of a 35 is very very rare if at all
my mates classic sti hit 355 on meth but the turbo was blowing out its balls.... about 1.5 bar , no dump valve, and didnt last long!
meths cheating :p
need to decide if im gonna meth mine or not . leaning towards not so i don't have to **** around with it.
I think meth must be the next logical step for yours tidg :laugh:
meth is a pain in the !Removed! to deal with
Is it worth me getting the sti intercooler or am I ok with wrx one ?
wrx is fine though if you find a cheap sti one its ok
Would the sti intercooler be pointless without the sti undertray and scoop?
4 minutes ago, Tidgy said:
It's not a huge upgrade over the wrx anyway, but ideally you want the undertray as well
Yeh, then I think you will need to get the STI scoop as I don't think the STI undertray fits under the WRX scoop
I'll leave the wrx one on then
Right guys I could do with some help , changed my turbo to the vf35 and put the sti injectors in. I went to drive to get my car remapped and within a mile my car started overheating and I losing coolant. I managed to get my car home after I put some water in it and let it cool down, I've done a compression test all seems fine could it be a airlock ?
Ok cheers
