Time i had my own thread
Just needs replacing mate i used the one in the kit pic below 20170305_143013.jpg
It allows ic pipe past but you retant the original cap see pic below
Also mate when you have cut all the back of the opening below the reg plate off the bumper if you use 2 screwdrivers in the bumper holes it makes it much easier to get the cut marked up wi must of had it on and off 30 times but the result looks factory if you look in the pic below you will see a red and yellow screwdriver holding the bumper on20170305_160304.jpg
The masking tape is still on in the above pic we used that to draw our marks on then when finished sanded the back edge so it was neat and left no ruff edges obv dont sand the painted part just the back cut edge
  • Replies 130
  • Views 22.5k
  • Japspeed kit mate and yea they did it was a set back but in a way i bought an unmolestered one so its swings n roundabouts Update wheels and calipers dun today not as light as usual gold but look
  • @Fastboy67 I had a punto turbo years back and fitted one on that with just a socket set and a grinder so now im older and wiser 😉 plus i have all the proper tools needed im sure il be fine
  • @Seminole81 pics below mate and cheers for compliment ive got new coilovers and rear arb fter fmic install then full engine dress up lol i get bored when im not tinkering lol @Fastboy67 whats you
What's the black plastic bit like just under the number plate holder? Could that be cut out too? Just a thought
Do you have the I/c spray fitted to yours, if so have you looked at moving it to front bumper for the fmic?
The black plastic bit could be removed but the intercooler slopes in at the top so i thought it might look abit daft so i left it also i havent moved the i/c soray line it would be really easy but i cant see if bieng benificial as its head on with air now isnt it so abit of water wouldnt make much diffrence.
Right then updated pics of the new dump valve fitted (cheap one for now till i pick the one i want)
Also today i debadged my grill to give a meaner look and also after advice from other members removed the black strip from behind the reg plate to see the fmic more
Also installed some pink mishimoto rad stays finally
Quick update ive just ordered my coilovers so fingers crossed i can get these fitted friday and 4 wheel geo set up done 😊
Right new dv today and map tweek at scooby clinic took the car from 325 to 340bhp which was good 😀
Also had new header tank fitted and colour matched to perrin induct kit
Before
After
Also got my cold feed kit in post so il look at this over the weekendIMG-6b2398fe0d1f87de84707fae743c33f9-V.jpg
Today i fitted a cold feed to my induct kit simple job in paper pain in the !Removed! to get the pipe down the wing with the intercooler piping anyway results are
@TidgyI like seeing it tho mate so il take that risk lol
There's only 3 shocks there ?
Yea thats right lol massively dissapointed but i bought direct so called them as my cars booked in at scooby clinic wed for fitting so there shipping a full set to scooby clinic for first thing wednesday morn so i cant complain the lady was really helpful too
Keeping other 3? 😁
Ordered this
Come at me bro
Waaaaaaaap stututututu pop !Removed! waaaaaaap.......etc etc
Edit
Imagine rusty nails in an empty paint can
Then add nails down a chalk board
Then wen ur watching tv and the adverts come on 1000000 times louder than the programme your watching and it makes you jump.
R-E-V-E-R-S-E intake!!!!!!!!!!!!
