Help headgasket gone
Hi guys anyone know how much a headgasket replacement is?
Sent from my SM-G928F using Tapatalk
Don't want to sound negative, But if your head gaskets gone it's basically a full engine build to fix it correctly , so your looking at thousands
Really why ?
Its not that much.are you doing them yourself.most the cost will come from garage labour and having heads skimed if they need it.
Need to do both heads for start and the big end bearings will have probably suffered. So no point spending 1.5k on a head strip down & rebuild for the engine to have to be pulled in a few months to do the bottom end and replace all the bits you've already replaced
Don't know what to do need fixed and sold
How much is car worth fixed and running? If less than 4k break it instead
It's a 03 blobeye wrx with 46k mileage
Done a pressure test and a dye test
Its only gunna be worth 5 max isnt it so the money side of me saying break it
As Rps said break it,or just cut your loss and sell it as it is.
You always copy me @Tidgy 😉
Yeah I'm selling it for 2k
I had a 07 wrx hatch that head went on it.if the car had been mint everything else i would have fix't it,but after a think and the cost and how car was i decided just to sell n cut loss,well i part x it for a blobeye.
How bad has it gone ? Is it just pressurising the water hoses a bit with no adverse effects in running and only using a little bit of water, or is it fully knackered, blowing out coolant/mixing coolant with oil, smoking,  rough running etc
2k still steep for a wrx with a blow engine mate you can pick a looked after one admittedly with 100k on same year for 2.5 to 3k mate ypu would need your head looking at to not buy a runner for 500 quid more
Sorry as you prob dont wanna hear it but it is what it is
Sold it for 1800
Did really well there i wouldnt of paid that with whats on paper
You'll be surprised how much interest in had within 10 minutes
They will all have been after it cheap to sell parts n make a bit on it.
