Turbo timer
Getting a hks turbo timer are they any good getting it for good price so couldn't refuse heard there good but because it lets car idle and turbo cool down before switching off
  • Replies 61
  • Views 7.4k
I have one I like it ideal for just popping in the shop or picking the kids up from school :)
They're not actually necessary in a Subaru because they are air cooled, best just to run off boost for the last mile or so home. Having said that I think they are pretty cool and have one installed on my, cheap and real easy to install. Great to warm car up on cold morning with the doors locked and no key in. HKS get the best reviews with all the different functions it has. Still run off boost before getting to destination to let turbo cool.
Got it cheap heard good things about them should have it by end of week are they easy to fit
Yeah easy as can be assuming you have a harness like this one:
http://www.ebay.co.uk/itm/HKS-Turbo-Timer-Harness-Loom-Wiring-Subaru-Impreza-WRX-STi-Classic-GC8-1992-1997-/230818070464?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35bdd43fc0
assuming it has the same ignition set up as my classic, was just a plug below the steering column which you take out, plug into the Harness and plug the harness into the turbo timer., I then tapped into the handbrake cable near the handbrake itself and ran the cable under the carpet and have the box under the steering column and the display to the right of the steering wheel. Took about 45 minutes to install including taking everything apart and putting back together.
Thanks sounds easy enough do U have to wire it in to handbrake
post-1928-13964522495_thumb.jpg this is it
You do have to tap it into the handbrake, the turbo timer won't come on if the handbrake isn't on. Or in theory you could put a piece of metal on top of the handbrake contact and trick it into thinking the handbrake is on all the time but the dash light is on, or you could find out what signal the hanbrake gives off and replicate it somehow. Although I would keep the handbrake on if not in car and the engine is on.
Yeah you do but I'm guilty of not doing that to others disapproval :D just the earth wire did it if I remember correctly
I do live in a hilly area so leave the handbrake on and in gear out of habit. Mine didn't work with just the earth wire.
Alryt is it easy enough to tap into handbrake thought I could just plug it in lol
There are a few ways to do it, the cheap and easy way to do it is to strip a section of the insulation off the handbrake cable, remove some insulation from the end of the handbrake cable from the turbo timer. Wrap the end of the cable from the timer around the exposed handbrake cable and then used electrical tape to cover. Or you can solder the wires together at some point, essentially there needs to be a physical connection between the handbrake wire from the turbo timer and the actual handbrake wire. It is simple, I did it without any specialist tools or equipment just a Stanley knife, if your not confident you buy something like this http://www.ebay.co.uk/itm/Posi-Tap-6pc-assortment-pack-wire-connector-607-6-10-22awg-/380871386000?pt=Car_Audio_Video&hash=item58adb42390 but first I would watch this video on how to tap wires https://www.youtube.com/watch?v=Jtvi7bGenC4 essentially how I did it and works perfectly.
Ok thanks should manage it
Had one on my first impreza , second was in the insurance not to fit one
How's that insurance company's not like them
I imagine they don't like the thought of the engine running with no key in and nobody with the vehicle
Because the engine's still running while the cars unattended .
My alarm system has a hiden switch and turbo timer built in but, if you open any door while it's running the alarm cuts the engine, immobilises the car and set the alarm off .
Alryt never thought about that still goin to fit it they sound cool lol
I can't remember how I wired mine then I know I wired it to something to keep it running. I like Savages idea with the alarm I did wonder if that is possible.
Yep you can rob the car while it's fitted / unattended
The sellers writing instructions done so should be ok is the handbrake wire under steering colum aswell then
Not saying how to do it on here lol
I believe it is under the steering column but not sure and don't know the colour, if you take the centre console out and look below and on the drivers side of the handbrake you will see a wire and contact, you can trace that back, mine seemed to go somewhere under the carpet so I just tapped into it there and then hid the wire to the turbo timer under the carpet up the side of the transmission tunnel.
Not wanting to rob it lol on about the where u tap it into handbrake is that wire under steering colum aswell
Got it today and look the wire to module is cut waiting for seller to get back to me as he never said nothing about it before sure I can sort it with a block connector or somethingpost-1928-139661419266_thumb.jpg
