Couldn't get turbo to boost on remap
Hi new to forum did a quick search **** findex owt so thort I'd ask. I recently had my 2008 wrx hatch remapped and the mapper told me he cudnt get the turbo to boost he sed he wanted 1.7 but only got 1.2 so not as much power as I wud av liked he told me it's cos it's on fully synthetic n I shud use semi synthetic oil seems strange to me tho any ideas? Also car has turbo back exhaust n piper cross panel filter
A place called the Sheffield rolling road.
Agree with ghost, that's a weird thing to be saying, the only thing the oil does is cool & lubricate it, has should have no effect on what it spins at, they rotate at 100,000 rpm plus so a different oil shouldn't make a blind bit of difference, I've been told fully synth is slightly less viscose than semi so in theory according to your chap it should work better ?
What kind of power are you after ? A 3 port boost solinoid would help control the boost better,did he give any indication of it was holding ok or bleeding off stx
No he did the give no indication of holding or bleeding off n at min it's round 250 mark was looking for 270 280ish power wise and as for oil I took it as him talking **** to be honest
I'll av to av a look into that m8 mite av to be ecu tek route
Don't no wat afr is lol n full turbo back exhaust n panel filter
Get wat u mean with afr nar n no dint c it n yes both cats av been removed also forgot to say earlier run on 97 octane cos shell n testing to far from me
The fuel plays a part too. Lower octane is more prone to producing detonation(knock). Again the mapper won't push the engine far enough to constsntly knock and regard the timing. Fuel can contribute anywhere up 10-15hp
Use a proper Subaru mapper is my advice
Cheers ghost n forgot to mention torque is bout 311 lb ft dint get why so much more torque than power after map n they race impreza n specialise in mapping them so thort I'd be gd using them
Fuel would hold it back, but still should have hit boost as if it was Honda vtec getting dyno'd or mapped it should still hit vtec.
I think it was boosting. From what I gather he got 1.2bar but wanted 1.7bar.
Ah right, what was the standard uk imprezas running when they first came out? I.e, were they any specifics, not sure what I'm on but feels quick enough when I hit boost lol.
Scooby clinic is looking like an option maybe getting cobb but not sure how cobb v3 wud work with car already been mapped
No refund possible gunna go cobb v3 I reckon but gunna look up how it works with remap already done mite av to get a reset for money spent on it its equal the my brothers 3 mps or mazdaspeed 3 depending where ya from
N his mps is standard dyno'do at 236bhp
