Piggys (slow) build
Removed valve guides and oil restricters from heads, tapped head with a hammer while doing guides right where the head gasket seals the cylinder, have dinged it, so that'll have to be welded and skimmed, bummer, have got new supertech guides and seals to go back in, and have had a play about with the bonnet scoop lol
  • Replies 71
  • Views 12.7k
  • Piggysniffer
    Piggysniffer
    I know they aren't exactly engine bits, but had to have em 🙈
  • Piggysniffer
    Piggysniffer
    got a newage sti undertray to go with the sti cooler I bought off kershaw, it doesn't fit under the hawk scoop as the scoop is too low, there isn't a bigger scoop for the hawk, so am gonna fabricate a
  • Piggysniffer
    Piggysniffer
    Pick up arrived today, so that can go on with sump, then can get on with heads and porting headers, and get them fitted
looking good that mate,i personally would give the end plates some curve so it don't look boxie,but i'm likein it :wink:
Looking really nice 😆i hate it when you do a error yourself and cant blame anyone else for it unless it was the hammers fault🤔keep up the good work..
Lols, just messing about with it at the mo tbh, I liked the scoop more when it didn't have the second bend in it to bring the opening down a bit cos I thort it might pull the bonnet off at speed 😜, might remake it, but first will shape those sides a bit more, probs cut it away on the top and taper the sides in at the top, then fit some ally spindles in the opening and mesh it 🙈
Valve guides are all back in, heads still measure 127.5mm so will have a little skim done, tigged up the little dint I put in it ready for the skim, and "adjusted" the scoop a bit 😜
Latest addition to the cause...
Sounds luvverly !! Gonna be awesome with a proper turbo 😎
Got some new bits for the build 😁
26 minutes ago, Jay762 said:
you know what would really set this build off is one of those JDM tow hoop thingies.....
:biggrin:
:bag:
Id agree get a tow hoop mate itll just add that sumit special ☠
A bloke from royal mail sells em on ebay .. u want link 🍿🍿🍿🍿🍿🍿🍿
Ok got some more bits towards the build
Williams racing headers
harvey uppipe
kelford valve spring set:-
KVS1847-BT VALVE SPRING & TI RETAINER SET
Manufacturer Kelford Cams
SUBARU EJ20/25 2000 - Current. Ovate wire, PACALOY Beehive valve spring set with Titanium retainers. Nano-peen and gold nitride surface finishing treatments for superior endurance. High frequency, increased seat pressure, low open pressure. Designed specifically for the Subaru flat four. 100lb seat pressure at 35.50mm installed height. Coil bind is at 23.00mm. 12.00mm maximum lift.
A pioneer avh-x8700bt
Some bits from icp:-
Heads are actually still at machine shop having stud holes drilled out to 14.2mm, then off to have a small skim, next thing will be a set of supertech valves and collets, and then do valve clearances and get heads on, then we will get onto oil pump, cam belt, clutch, turbo 😳
Oh, and the bonnet scoop is nearly finished, probs gonna have it satin black 🤔
  • 4 weeks later...
  • 5 months later...
That's it, the dream is over, scoob has been traded in for another car and all bits for build being sold off 😶
