Dump valve choice
Ive got to buy a non flanged dump valve now i have a fmic so which one is a good one? The louder the better as im a chav a heart.
Any advice guys?
I personally love the sounds of the HKS ssqv
Agreed [emoji13]
It does sound good but i want something more brutal if that makes sence
Screamer pipe ?
Thats abit ott lol i just want a loud tschh my old dv is a hybrid gfb one so might just get the same but flangeless as i liked that
Can you not change the adaptor on them?
Think the base plate that bolts to tmic is threaded, unscrew an buy the correct fitting to screw in, must be cheaper and if you know you like it then win win
GFB have a nice PHSSSHHHHHT to them... :D
do turbo smart do one? think they do one which you can alter the sound on
i had a TurboXS (ebay job) on my old classic years ago was !Removed! loud!!!
Turbo smart the one you can adjust between recirculating and atmospheric?
no idea i dont run one..... pure wastegate!
I was looking for a turbo xs one.ive juat bought a cheap one from local motorfactor untill i pick the one i want and order it
Don't honestly know what's on mine, might be a baileys one, but I also might be wrong
How much does it sh ag up the turbo not having a dv at all?
I think matt knew someone who ran without a dump valve, i've read that ball bearing cored turbos don't like it much .
Maybe get a adjustable one and stiffen it up a little bit to get some more flutter but not abuse the turbo too much .
I ran without one and so did my mate , yeah you won't get a long life out of a turbo but I never had a issue
I have a YouTube channel with a few videos of my scoobie on, search Matt Kane, should be fairly clear lol
Agreed, my GFB fully open is quite loud... you can also turn it off when you get bored and has an adjustable spring so it doesn't cause ECU problems.
Is there anyway to buy a connection to replace the flange?
I had a Baileys on my classic for a while but ended up getting rid of it and getting rid of the silencer box instead. Much better! It sounds exactly like a dump valve and suprisingly very loud.
Whats a silencer box?
On classic wrx's inbetween the airfilter and engine is a big plastic silencer box. It stops you from hearing the turbo noises and intake noise from the airfilter. I got rid of that and now have turbo spooling noises and the standard recirc valve noises. The turbo makes awesome noises! And the lag i had is gone! It wasnt loads of lag but noticeable. I reset my ecu with the dv on but it didnt run perfect. Stuck my hks induction kit on, reset the ecu and its sharp and noisy! LOVE IT. Although im going to buy the Apexi one as I prefer what ive read about that filter.
On your car im not sure but there must be a factory silencer somewhere stopping you from hearing the induction and turbo noises?
