Rear Inner arches repair - 99 UK Impreza 2000 turbo spec
TonyCee
Hi guys,
I'm new to the site and looking for some help on how best to address the rear inner arch issue which seems to plague the older Imprezas.
Most of my inner arch has been reclaimed by nature, heading upwards to the turret top of the rear suspension.
Assuming that several members on here have experienced this problem; is there anyone who can provide guidance as to the best approach to repairing these,  eg., is it necessary to remove suspension, petrol tank, etc?
Any help on this would be gratefully received.
Best regards,
Tony
If its totally goosed, then best /easiest option would nbe to buy new rear quarters and have the body shop cut out evrything and weld in the new, not cheap but the only way to be sure youve got it all and done a prroper job.
@savagebulldogs knows someone who has had this done and may still have some pics
Sent from my SM-T210 using Tapatalk
Thanks for the reply. It's fairly goosed but I think I might get it in time before that's necessary (I'll see what my welder says).
The car does need new outer arches welded in also (totally gone) so it might come to it that I need new quarters.
I didn't see anything in the how-to guide section so I thought I'd ask you guys anyway.
Unfortunately most of robs pics were on photo bucket but his way of getting rid of the tin worm was probably the best but most expensive I've seen .
He has all his work done by Roger Clarke and had new inner and outer rear 1/4's imported from Japan. Thorough job but a £8k price tag [emoji857]
Stants Probably recommended the most used route but if your welder can make the inner arches and turrets solid ?.
Have a look for "automotive repair panels " page on Facebook.
Ray sells good quality gc8 outer rear repair panels and sills at sensible prices .
Let us know how you get on and best of luck with saving another classic [emoji106]
Impartsb46 on eBay often have body panels rear quarters etc for sale, just had a look there nothing for classics at the mo but may be worth mailing them to see if they have them or can get them
He has all his work done by Roger Clarke and had new inner and outer rear 1/4's imported from Japan. Thorough job but a £8k price tag emoji857.png
Let us know how you get on and best of luck with saving another classic emoji106.png
@savage bulldogs @stants thanks lads. This sounds like it could turn out much more expensive than I had initially thought. Here's some pics of the car anyway. Your thoughts on the colour?
Looks like a clean unabused example [emoji41]
Didn't want to scare you off with robs £8k price tag, as you could probably get it done for less than a 1/4 of that price [emoji6]
Pending how bad the inner arches are, whether you get the whole car sprayed or just the rear 1/4's and who you use to get the work done .
Yeah I decided to go for this one (knowing about the rot) as the previous owner had it for 12 years. Totally standard car apart from the back box. The car is getting treated to a full respray as the paintwork is worse than the pictures show.
I'll likely get around to a full service first. As I've always been a Toyota and Honda man, I know nothing about Subarus. Can you point me to a thread that contains all required servicing information  (what belts, oilso & their specification, filters etc to use) please?
No real thread on parts to use but I'm sure you've come across www.importcarparts.co.uk ?
Best place for oem stuff,
I'd use genuine subaru oil filter, blue ones are about 9 quid while the black ones (supposedly better) about £12.00
Air filters most of us use cosworth dry foam type, saves the maf form getting oily.
Oils any good fully synth will be fine again most of us use Miller's
10-40 is recommended for classics (unmodded)
As for the belts you can get full kits from ipc again
The gates/blueprint belts are good depends on what price range your happy with
Hi I just brought a 2002 Impreza WRX wagon two weeks ago. It is currently in the garage having a full service  at 900 quid! The sparks plugs broke in half on the mech when he took them out and the fuel filter looked like sludgeville and whilst in there, they have found EXTENSIVE rusting to the rear wheel undersides where the shocks sit in - have just had it welded last week and will get it back tomorrow and the bill for just the welding - which the garage tells me is as good as when it came out of the show room - bill will be 800 for just the welding job!
The garage completely stripped out the rear interior and I apparently have completely new rear wheel arches. Got to love the classic cars though as so many have trashed/smashed/scrapped. I won't be modîng mine up mind not after the garage bill anyway! Just one thing left to do to it and that's get rid of the pink stars badge on its front and the pink STI badge on the back.
Good luck with your classic
Just got my scoob back late yesterday, I asked the garage to take pic of the welding job before and after to be able to post on here so you can all see just how BAD it was! The bill made the hubby gasp too £2000!!!! Was a full service to with all filters plus drained ALL fluids (brakes, power steering, trans etc) and replaced. I shall be running scoob forever now never having another car now lol.
  • 6 months later...
On 7/22/2017 at 8:36 AM, Jay762 said:
Wotcha and welcome - would be great if you could get photos of the work as it goes along - start a project thread :thumbsup:
Hi guys,
Just to let you know that I finally got most of the welding done (inner and outer arches, petrol tank neck, rear bumper bar, subframe, various patches in the boot) on my GC8. A few outstanding items (the Shell was really bad in places), just wondering if you are still interesting in seeing pics?
  • 3 years later...
hi all, just got my 1998 terzo3 out of garage after standing for last 20mths and took for mot, yes it failed badly server rotting on both inner wheel archs  were suspension is, took to body shop and he says best to cut in whole rear quarters if i can find some, does anyone know were i can find  some, and for him to do both poss change both front wings refurb wheels and a full respay looking about £6000, does that sond about right
to do it right is a big job, if the inner arches are rotten up to the suspension towers then its going to be big rebuild job. 6k maybe there or there abouts as it gonna need taking back to the bare Shell, rust cutout, new steel welded in, then built up, before being sprayed. im assumming the full respray is a full strip and respray, glass out, interior out etc etc, short version, its a duck tonne of work hours to do it as i bet they have priced it based on finding alot more like sills and such needing to be done as well.
