My build/conversion project
It's been a quiet day today on the build :(.
I have, however found my stash of parts that I put away over a year ago :)
Mainly gaskets and seals and stuff so not very exciting to photograph.
I did get a couple of phone calls today that were very welcome. One from a supplier to tell me that my order will be with me tomorrow.
The second from my machine shop to say I can collect the heads in the morning.
That means, depending on the postal delivery time, the build can start tomorrow afternoon :) pics of that will follow.
  • Replies 219
  • Views 41.2k
  • MOT, passed, car taxed, time for running in
  • The off side head is the same as the Impreza turbo. The offside is also the same except for having oil feeds at the rear for the other turbo. The oil galleries are present on the single turbo heads, b
  • As promised. Next update time :) First some info before news of the work. I've managed to obtain the rotated up and down pipes required to cope with the GT35. I still need an exhaust manifold to su
Quiet day busy one tomorrow by the sounds of it  at least the day came with some good news so not that bad really :)
Post didn't arrive until after 4 so no build fun today.
I did collect me heads though and I'm very impressed with the work.
Hers a before and after shot:
Before:
3560EE24-3D77-405D-8A1C-BBAC64D3ED9D_zps
After:
17F7D262-7314-440B-8598-F1335ACB559E_zps
And a close up of the work:
BE3599A8-67A2-49AB-9E0B-FAB2AF62B46D_zps
In the parcel, along with seals and minor stuff was this too :)
EAC1E0F0-7DC2-4649-9AD7-701EAA1A54C3_zps
I am however, in a position to commence the build tomorrow morning :)
Amazing how much !Removed! they get on them heads can see a real difference with them almost as good as new. Let the building commence :)
So, today engine building started
First, all the con rods were cleaned and checked over. Then the new bearings fitted with a good dose of paste
F5793DBC-4DEF-4505-9FAC-1D004B60A1C7_zps
Next, each Conroe was fitted to the crankshaft, ensuring they are the correct way around
D619EF3D-5B9E-439C-AE6A-FB3A63F5FCC8_zps
The bolts were the. Tightened to the specified torque.
Once all 4 are bolted up and feel good, attention turns to the crank case.
Already thoroughly cleaned, it just needs a blast of compressed air to blow out any dust
That's collected. Then the bearings are fitted and paste applied
FACB287C-23E8-4F6F-8D07-266CA0F0D035_zps
New o rings are fitted along with the crank assembly
2B03B153-00C4-475D-BAF8-076709F7066B_zps
Then the bearings and paste are fitted to the other half. A very thin layer of sealant is applied to the flat surfaces and the two halves put together.
Then it's time to put the bolts in. This is all the bolts just for the crankcase
A6222493-E30B-453A-AC31-F9CCF8ED495C_zps
That took most of the day. It dosnt seem a lot of work, but everything is dry fitted and measured several times before actually fitting.
Nice job so far. And I was always told if a jobs worth doing it's worth doing properly, so take your time. And I know 1st hand how time consuming some jobs can be and you feel you didn't get much done. But I think it's already starting to take shape :)
Ooh looks good. I'd love to be able to attempt something like this.
Pardon my ignorance but whats the roger clark item that arrived in the post picture ?
That is a sump baffle plate, it stops the oil sloshing about improving the feed to the pickup, minimising the chance of oil starvation and also going up one side of the engine or the other under hard cornering
Ah thought it may have been but bever seen one out
Had chance to do a bit today, after sorting out the garden fence from last nights winds.
Today was about the heads, well, 1 of the heads anyway :)
Time put them back together. First up, new valve stem seals and sorting the valves out.
5FD7DC8B-E1C7-4676-96AA-6E3FDE006AA4_zps.
Then, once the valves had all been cleaned up with a wire brush, it was time to lap them in and reseat them
6045698E-8D55-46D5-8B07-84C6CA4BADAB_zps
All 8 valves in
8FBCAA66-0068-4FBC-B162-5EB8C5FA0FE0_zps
Then the bit I dread most, fitting the collets to hold the valve springs in. It's such a fiddly time consuming task.
Done :)
C76FA8D4-750A-4CA8-9AD6-43C679ED8C0C_zps
Well, that's one head done anyway. One more to do, maybe tomorrow
Nice job halfway there :)
I'm guessing that bit would be at the point all my tools are Sh@t the engines Sh@t and I curse my life for being so damn difficult type of job then ;)
put it this way you need a steady hand and make sure no hammers are within easy reach - there are tools you can get which make it easier to compress the spring whilst you put the other bits in place though which really help
Arrhh I know exactly what type of job it is now.
I have one of those tools which are great but you have to use needle nose pliers to put the collets in place.
Problem is, after about the third use, the pliers suddenly become magnetic and won't let go of the collet.
Then you have to use a small screwdriver to hold the collet in place as you withdraw the pliers. At this point you need 3 hands
But only have room in the work area for 3 fingers. It's THAT type of job :)
worse than doing the spark plug swap then :)
Today was a good day :)
Got loads done but started with a box
C3FBEE30-292B-4105-8BD6-D50574302DF2_zps
First step is a fiddly one, fitting the new piston rings
E818961C-EFB6-48D2-970D-4D76492DB034_zps
Then on to fitting the pistons. That meant putting the block back on the bench
7143025D-0B4D-4DCD-9A75-99E942956900_zps
7DA0CB76-0F0F-4372-AA0A-BB88B16982DC_zps
Once all four are fitted, it's time to put the block back on the stand.
Next up was the oil pump. Shiney:)
E027BEF3-AC1B-4278-9C6A-1DB7FBD84612_zps
And finally for today, the water pump.
00146140-F809-4B2C-8155-0900D3F03B0A_zps
It's looking good now :)
Nice, I must be the only one who has never had an issue with valve collets. Various much simpler tasks have been messed up though :)
