Gauges and pod
Have you checked both fuse boxes ? Mine went and couldn't figure it out turns out it was the 20amp? in engine bay box
  • Replies 81
  • Views 8.4k
    Were the fogs working with just the boost gauge connected ? I'd disconnect the other gauges and double check any fuses starting with 10 amp (normally red) preferably switch each fuse with a spare go
  • I had sane problem try www.etsracing.com it's only a small company and he hand makes the stuff so fit may need to be trimmed. Scooby part and world do them aslso but are a bit more pricy
  • Yes they light up amber...If i cant fit them i'll have to ask someone on here :) For beer tokens All it says is oil and water sensors included full fitting kit with instructions   I ordered boost,
Theres power going to the white connector which plugs into the back of the cig lighter.Ive got a multimeter and have been using it,i haven't took all the scotch  clips off the cables ive been using-not yet anyway.Checked the fuses visually inside the car,and in the engine bay,but my neightbour says just because you cant see a break,doesnt mean that's its ok???God p***ed off
I'd disconnect the other gauges and double check any fuses starting with 10 amp (normally red) preferably switch each fuse with a spare good fuse of the same ampage or check current passes through them with the multi meter (as visually it's sometimes hard to spot a break)
As it sounds like you've earthed something out mate , Cos if that circuit is designed to light two big fogs and a ciggy lighter couple of gauge lights shouldn't blow the fuse .
Sorted :) Went through all fuses in engine-ok,then inside fuses-it was a 10amp(illumin),must have been hairline crack.Replaced and then started on the last gauge which I was working on when all this started,and it blew again! The bulb holder had a dodgy wire on it.The wire which has a base on it where the bulb sits on.Cant be arsed to send it back so do you know if maplins will stock a little holder or just the wire with a tiny base on it??Cheers for the help guys :)
Oh good result  :D  I'd say you can find anything in maplins if I can find my out of date catalogue I'll have a look through :)
Think there's a "how 2 " sticky thread on s.c in tech section for fitting a oil pressure gauge .
Although it's for newage it's probably a bit more explanatory than my ramblings and 2 dodgy pics [emoji5]
Glad you've sussed it bud [emoji106]
Tell me about it! Im only going to wire the oil press/temp up just so they light up for the moment.Might get someone else to do the other stuff another time.
