Japshow Finale Santa Pod 1st Oct 2017
2 minutes ago, savage bulldogs said:
Is there enough space left on the stand for me , Geoff ?
Yes mate your down 👍
  • Replies 126
  • Views 16.1k
  • Now then! Tickets and passes sent out today 1st recorded.  Still got some passes left so dont be shy!!
  • Bit late replying but I basically echo everyone else. Thanks for organising it! Shame weather seemed to stop a lot of people going, was very quiet but still enjoyed it. Definitely going to try my best
  • I'm up for it mate just hope that the car is ready for it 😀😀
Well I have news for you all my car has moved today got the engine in yesterday and bolted it all up today just took it for a quick test drive as only one headlight is bolted on and window screen is still cracked but all seems good via one error code on ECU saying p2444 secondary air pump fault but all good apart from that 😀😀😀😀😀😁😁😁😁😁😁
On 08/26/2017 at 8:19 PM, GeoffLeggy said:
Hi, should be ok, I'll give them a quick call next week when I'm back to confirm I've got the 15 spaces.  I'll let you know.
Hi any more spaces left? I would like to get one? Thanks
Sounds promising mate! :punk:
@GeoffLeggy it definitely does mate just got to spray the bumper and the body work will be done still need a couple of bits and then found that my sump has a small hole in it and has been leaking oil all night ☹️ but sealed it up today so hopefully won't peak all oil need a new sump to be on safe side window screen is getting replaced on Monday too all airbags have been replaced as well as all sensors and airbag ECU so all looking good will definitely be there is my Subaru this time 😀😀😀😀😀
3 hours ago, GeoffLeggy said:
Yep no problem.  Pm me.
Hi it's not letting me send message to you, can you pm and ill give you my number.
Are we meeting anywhere before hand and going in together? Or just meeting at the track?
@GeoffLeggy well it will be finishing off the bodywork and polishing it window screen was just fitted but they supplied the wrong screen as it is an inch too short so they have to get me another one just what I need 😬😬
Oops! 😩
@GeoffLeggyHow much do I owe you for my Sunday pass mate? I'll get you money sent over.
@DaveRACI'm in Sheffield too and going on the Sunday so I'll go down with you if you want?
