Rollamite's 96 Impreza Sport Project
Rollamite
I managed to source two sti spoilers, 65 for top and 80 for bottom, so not too bad compared to the 100 a piece i was willing to pay, also got my alloys done in a metallic black/purple colour ready to go on;
and sprayed and fitted my larger scoops, used a little left over mesh to help protect the i/c, should be putting my larger alloy one on tomorrow hopefully its just a little stubborn
sadly i have work commitments, so its guna be another time :( got my alloy i/c on as well finally! had to use the stock y pipe though as the other didnt fit very well, stock is thinner but has a wider opening to the turbo itself at least, took for a test and was leaking boost so i addressed that then had an idle CEL light on that went when revved, tightened everything to within in an inch of its life and touch wood seems to have solved the issue, not road tested properly yet just down the back roads and you can notice the difference the alloy one makes!
good news! ish, i got my sti spoilers painted and on the car they look great, took my car down to scooby clinic to be remapped and they blew it up, heater matrix went, took the HG and cooling system with it, ~£840 later no map and a broken car but i got a new heater matrix and a walbro fuel pump at least...
took it down to Rotherham scoobies and had a bottom end refresh new cosworth cambelt and HG and got the car remapped by duncan graham pulling 262bhp which isnt bad for a car built with 217bhp standard, new apexi induction kit, new DV as im now MAFless, new alloy rad and hoses, will have pics soon, but now im facing dodgy idle, keeps idling at 1200 when warm so i have adjusted thje iacv and will clean it this weekend hopefully its nothing serious.
other than that the car is well
  • 4 weeks later...
UPDATES:
Got a small reg plate and fitted my glow in the dark Jap plate to the front, got a debadged grill sprayed it 406 and fitted that too, pics this weekend hopefully!
Small 2p size rust patch forming on the rear arch so im forking £300 over to have the rear quarter sprayed and wax injected into the skins.
Fitted my Japenese Kei alloys, forged lightweight purple goodness, replaced the manifold with a black one and sorted, to an extent the ile issue, still creepes slightly but no were near as bad, learnt my lesson now if it aint broke dont !Removed! tinker with it!
I also got a dog called Poppy
PREPARE YOURSELVES;
Lot of pics I hadnt uploaded previously;
ALLOY TMIC TO COMPARED TO STANDARD
alloys WITH PURPLE GRENADE DUST CAPS
ENGINE BAY PRE REMAP
DRIVE PIC MID BUILD
ON ROLLERS SC
AFTER REMAP ENGINE BLOW UP... LOL JOKING JUST AN OLD Shell I WAS SNOOPING THERE
GRILL ON AND GLOW IN THE DARK JAPANESE LICENSE PLATE AND SMALL REG PLATE FITTED
OLD AND NEW
PURPLE TOW HOOK
ANOTHER FRONT END PIC
CARS IN THE PARK HEDLEY HALL UK SCOOBIES STAND
YORKSHIRE MODS MEET
BADASS PIC I LIKE THIS ONE
MOT TIME
PASSED WITH NO ADVISORIES, REPLACED WERE; REAR SHOCK, HORN PLUGGED IN, ABS SENSOR SO ABS NOW WORKS, SWAPPED OUT ORANGE SIDE LIGHTS AND SMALL PLATE FOR STANDARD, DONE THROUGH SHEFFIELD SUBARU SERVICE, TOP BLOKE!
WELCOMED A THIRD SUBARU A ROYAL SILVER UK2000 WAGON
Oh and my arch was redone, and a pin prick bubble came back up so they re did it and it cam back so they have offered to replace the arch with the front drivers side wing and redo it again for free, JR CLASSIC DONCASTER brilliant bunch of guys EXTREME PERFECTIONISTS!!
