Help, looking to purchase Hawkeye STi
All the 2.5 suffer from it, even the newest model (despite what some people claim, clinic hav already had 3 2015+ cars in with ring land/headgasket failures). Also seems to make no difference regarding tune. Exact numbers are unknown, but its very common indeed.
Actual failures or are they creating work for themselves again? [emoji23] [emoji8]
  • Replies 110
  • Views 11.7k
  • Welcome to the club Steve! Personally, I would go for the 04 Blob. 2 litre engines have less problems with headgaskets and ringland failure. I would still make sure that the cambelt has been done
  • walk away from anything in bradford. i noticed clives performance has changed name again ca performance or summit like that
  • Will check them out.   Yeah, peanut/blob same thing. I'm a Yank by birth, cut me a some slack 😉😂
21 hours ago, Seminole81 said:
Are the STi's supposed to have a front lip on them? Or is it a factory option? Just curious as that hawk eye doesn't have one...nor does it have the fog light covers it appears.
the hawk sti sould have foglights,their standard across all the range,if you dont see the foglight just ask when you go look at car they will have the cover over them,they just clip on.
Equipment List
Basic equipment
The basic equipment list includes equipment that is standard across all versions of the Subaru Impreza Saloon (05-08).
  • 3x3 point rear seat belts
  • ABS
  • Air conditioning
  • Alarm
  • Alloy wheels
  • Body coloured bumpers
  • CD
  • Driver`s airbag
  • Electric mirrors
  • Front electric windows
  • Front fog lights
  • Headlight washers
  • Heated mirrors
  • Height adjustable drivers seat
  • Isofix child seat anchor points
  • PAS
  • Passenger`s airbag
  • Rear electric windows
  • Remote locking
  • Side airbags
  • Space saver spare wheel
  • Steering wheel rake adjustment
2 hours ago, Scoobyghost said:
Actual failures or are they creating work for themselves again? emoji23.pngemoji8.png
Haha 😂
Ugh, very torn on what to do...think I'm starting to do my wife's head in now with it too haha 😂
Got the fog lights, just don't see the covers. I'll ask.
lmao, given how few that are actualy around to repair and service now you may have a point hahahaha
10 minutes ago, Jay762 said:
There are a few of us on here who have or have had 2.5's with no issues but there have been failures
yeah tis pot luck. i know some that have had the living daylights thrashed out of them cos they were planning a rebuild anyway which havn't failed, yet some that are babied that have :S
Seems to just be pot luck :(
1st hatch i had was standard 225bhp 2.5l head gasket went.sould have no it had not been look after with how dirty engine bay was.the hatch i have now is 320bhp and runs like a dream,but you allways have risk of it going wrong when you get a car as you dont no how its been drive,best if it comes with some warranty.
I wasn't planning a rebuild but was looking at an additional remap on top of the Prodrive flash it had received but I can say that each rev was used regularly and consistently in succession - none of the range were excluded :spiteful:
hehe :D
Well, for me and daily usage at the moment, I think stock is safest option.
Going up to JM tomorrow after work for another test drive and possibly out a deposit down! 😱😬 have a mate Stateside as well who had one, no issues. Seems pot luck...
Can someone confirm what the compression should read on the EJ257 engine?
standard 142psi - 171psi fairly sure, limit 128psi. Max difference between cylinders 7psi?
Viewed the hawk again...pretty sure I'm going to buy it. Love it. Just awaiting the timing belt check.
Whcih one was that?
Blue one with mot issues [emoji54]
If you do go for it, make sure it has a proper CAT1 alarm fitted and has been under sealed. Also first thing i would do is as soon as you pick it up head straight to a specialist to get it given the once over and dyno'd to make sure its all running ok.
Yep, it's been undersealed. Definitely going to have it double checked over.
Deposit paid though!
Proper pics required once in custody lol..welcome aboard!
Haha! Yeah! Don't get it till next week so I'm gutted about that! Full service, alignment. Compression test came back at 174psi across the board, so it's great. Timing belt and water pump both look in good condition and ready to rock! Can't wait to pick it up next week!
Personally i;d get the cambelt done, very easy to make em look good with an oily rag. Also its the tensioners that you need to worry about, they are the cause of failure 99% of the time cam belt is an issue. They are hydraulic and the seal goes meaning the belt looses tension and all hell breaks loose.
It was done in Singapore. They've double checked it for wear and everything. They're doing a full service of all fluids (trans., oil, brake, etc.) and have done a full inspection on everything else. Have to say JM Imports have been first class and nothing is too much bother for them. They're even doing a reroute for the DEFI gauges into the triple hood pod and a double A pillar pod set for me. Going to move the link into the glovebox to keep it discreet/clean looking (unless someone comes up with a much better idea quickly! Also thinking of setting the boost gauge warning at 18.5psi? That sound about right? Should be 14.5 from factory, but it's got a exhaust and intake on it...what's the best way to watch and rid of boost creep as I'm not entirely sure if it's been tuned (appeared so as it never really went above 1.2 bar and then tapered off). Keeping the turbo timer and APEX in the same place. They sent me this photo last night too.
Side note, does anyone have or know if any completely blown turbos that are scrap? I'd like one to try a little project with (lamp making?)
