Getting a Gauge set up for Christmas!
I couldn't find a 4 in 1 on there @stants
http://www.deporacing.eu/
Next day delivery etc
When I tried them they fobbed me off a lot. I ordered mine from a German seller on eBay. I'll see if he still has them
A bit pricier than some others but here it is.
Look at this on eBay http://www.ebay.de/itm/112122929717
He also has water temp versions but you lose oil pressure. Not a worthy trade.
Fair enough, just get 3 of the dual readout gauges then you have six things to be able to monitor 😂
Ive been advised i will probably need a sandwich plate for the oil pressure and temperature sensors. Had a quick look on eBay but how do i make sure it will be the right fit  on the thread on my oil filter?
cheers
It should say what engine it's for in the add. You want one for an ej20
Would advise against using sandwich plates. Cheap versions leak and hard to monitor. You can buy a T piece that will fit into the oem oil pressure hole and it allows you to keep the oem pressure switch. For temp it's best to go for the bung that's located over #3 piston. That's the usual hot-spot due to being so close to the turbo and uppipe. You'll also need an adapter for the temp sensor as the sensor uses a different thread pattern to the engine. I'll find the link for the parts.
IMG_6845.JPGthis is what the gauges are reading on idle after being driven. Sorry about the picture could t get it the right way.
My gauges read about same.then when warm and drivin my oil pressure goes up to about 6 bar,8 when first start up from cold.
