Forza Race event
I could have a go if you send it, let me know how you want it to drive as well i like mine quite twitchy for example
  • Replies 317
  • Views 26k
  • I'm not into drag myself, but maybe I could get my tranny out. Oh, god, gambit is rubbing off on me. OH GOD that was worse than the first innuendo! Quick, change subject. I should be about on Sund
  • Scooby Pete
    Scooby Pete
    I'm in the HB. Just whack on the mods with as much bop and grip as I can get then off we go. Never bothered with tunning set ups as I don't have a Scoobies how to set them up. The most I ever do is lo
  • Scooby Pete
    Scooby Pete
    Too much grief testing not enough know how to fix what I broke, I'm a just get in a drive type.
Do you race wheel or pad ?
Sounds weird but the with the wheel it feels totally different.
My mate and i built identical spec gt2's a while back. Then tuned, him on pad me wheel. We swopped cars and neither could drive each others, mine seemed too slow to turn in and a bit vague where as his was over sensitive. I guess you have to take the wheel into account with steering angles and 'feel' if that makes sense ? I like
I just dont have the time to put into it these days one of the reasons i couldn't justify buying the new xbox
I have a wheel back home so could try with that might just take me a little longer to get right
I use a pad always hated the wheel, I like a tight car that allows precise placement, that's why I have stuck with AWD, I'll send it over tonight. I'll save the tube do if you need to change the upgrades feel free. I tend to use a lot if street stuff over race to get more power and to use better tyres/ weight reduction.
I use Invar view and also only use manual gearbox although I've never used the clutch and no desire too, I'm learning enough already, I think I'm doing pretty well considering I've only just started racing without ABS and stability etc.
Using the Class D car as a base means you can change a lot of stuff which gives you more scope. Certainly the my old legacy is much faster than my 2011 impreza. That's why I can do a 9min lap in a transit because I can put a ford falcon engine in it without ever exceeding A600 Class.
Is the legacy a dlc car ?
I bought the season pass but didn't really pick any of the others up after that.
Saying that i spent a bit of time racing alot of the s class stuff.
it is I bought it for £1.29 just to see Dogs paint job but fun car I ended up R3ing it just to rag about so far :)
Ok im better at a pad ill have to check if i have the dlc i wont be much use without it haha. I like doing lower class cars up asi think they end up more purpose built, the 22b was doing my !Removed! in stick in a bigger turbo... Aaand S class ffs
Haha was the 1st time I see the crash. I see you lose control in the review but didn't realise the full extent  :lol:
http://youtu.be/LfooPijr0hw
Haha yeah cold tyres over cooked on the crest spat me across the otherside of the track game over. Was thinking about trying to gather it up but i thought i may have gone backwards into it. At the time seeemed like the best option
I've watched it a few times now does make me chuckle :D
Can only do 30 seconds too :(
And has to be the worst start on the 1st corner I have ever seen loads of shuntting going on :)
I will have a look at the video again see if anything else was worth taking from it
Just found another class moment will get that and see if I can see anymore :)
Didn't occur to me that i must have it if i could see it duurr !
Classic case of following someone else's braking point haha !
Bosh yep your right there, i forgot about the bora if you don't have dlc. I was too busy looking at the rothmans livery to pay any attention to where it came from
Dogs done a Legacy Rothmans one already :) only reason I bought it :D
Thats what i ment i was admiring it trying to catch it that i didn't realise it was dlc
Oh ok :)
I nearly went took the corner way to wide I think a few laps later was when I managed to over take BlackBOSH on the same corner when he ran wide on it.
When I came to overtake bosh I think he'd lost it and was swerving all over the road, I had to swerve to avoid him just at the breaking point to a corner, lost it again and never got back, too much damage.
Ok no Stanton500 but Dog and Pete going over to wave at fans ;)
http://youtu.be/vBhRqW6Fdsg
HA HA, I had a bit of an ABS failure again (i.e. I forgot I hadn't got it) and Pete was tucked in drafting and just followed me, Sorry Pete but in the first vid I had another ABS failure and you were just there  :P
Pete,
I sent it too Gambit, he can send you a copy or let me know and I can send it to you, save you doing it
