a little project thread of my turbo 2000
Oooo that's what I'm after more than a ything is the anti lag and launch, that's what put me off the esl board, if it's still significantly cheaper than most when they have that option I'll look into getting one
As for ecu location, it's on the passenger foot rest firewall area, lift up the carpet from under the glove box area and there a metal plate bolted to the footwell, undo the plate and you ecu should be there, as far as I know the majority of modified early ecu look standard as the boards can be switched out for the mappable one, if you look around the edges of the casing there may be a void type sticker over it as a precaution seal from the new ecu fitters
  • Replies 279
  • Views 36.1k
  • davievtec
    davievtec
    Lol I hope so ... im going to update the list with links to the exact products i am going to purchase over the coming months to give you an idea of what specification I'm looking to have some things w
  • davievtec
    davievtec
    Was back down the garage today and I took 2 photos one of a new addition and the other of the front split down so here's the stripped down image And heres the new addition
  • Ohh and also look whats arrived!! Happy guy now
Ahh thats what i thought i knew it was in that general area i will have a look anyway just incase it was somewhere else lol cheers guys
Basically i got bored today and decided im removing the indicators from the bumpers and putting them inside the sidelight units along with the sidelights and decided to change the colour of the needles on my clocks to pink turned out pretty cool i think what you guys think heres the pics to show what i have done all i need is orange indicator bulbs feedback welcome folks
IMG_20131020_164653_zps5ef47eb5.jpgIMG_20131020_164635_zpsf24ed005.jpgIMG_20131020_165327_zpsb5c4f648.jpgIMG_20131020_191351_zpsab5830aa.jpgIMG_20131020_193714_zps8dd2d9cd.jpgIMG_20131020_191151_zpsb16528ea.jpgIMG_20131020_191158_zps6e875bea.jpgIMG_20131020_202544_zpsa8cff514.jpg
davievtec
Top job mate look's great. How did you get the needles changed over with out making them off set ?
I did it once before and my speedo and fuel gauge was a little out. But managed to get my speedo back a little bit with the OBDII reader and Torque pro while driving with the dash out :D
The needles are just painted bud didnt wanna remove them incase i broke them lol im gonna do the inside a diff colour aswell mate
davievtec
Oh ok good idea :) does the light still illuminate them ok ?
Yeah mate only done the tops n left the sides clear so will iluminate il check today though how do i fully dissasemble to remove the green filter ?
davievtec
Not sure myself I thought it was to do with the bulbs. When I did it last on another car I used one of them plasma dial faces from ebay. And on anther car I send the stuff away to be made blue and a guy by the look's of it swapped the bulbsto LED and soldered them on where needed to make it all blue. But could be wrong
I was looking on youtube and a bug eye has some sort of paste on the back which makes the colour i dont know though would like black dials though
davievtec
I will have a look later see what I can find. I've not messed about with them on the Subaru's I've left them alone. It was an ST170 and a Focus I did the last ones ages go :(
I took the bulbs out of my clocks and removed the green rubber caps off the bulb, makes the dash a lot brighter now, I have the clocks before yours with fuel and water one the left and right corners
Ahh see mine is just normal yellow bulbs unsure how to take the green board off the back n dont wanna touch it incase i break it lol
davievtec
Well I have the same set of clocks in the garage that are on eBay now, if you want a spare set of clocks to dismantle we can sort something out if you like?
I have another set aswell mate im gonna experiment with them tonight and see what happens
davievtec
Have to let us know I'm interested now :D
I will do mate hopefully i dont break it lol
davievtec
Just keep away from using any hammer's should be fine ;)
Thats the fun part lol :(
davievtec
True but only wen using a nice selected choice of words as you scream die you piece of..... After it has gone wrong :D
Yeah usually if things dont go my way i tend to attack it with an oxy acetalene torch its very effective especially on plastics and fabrics
I also have the song "the roof the roof the roof is on fire we dont need any water because were gonna let it burnnn" playing in the back ground so is very fitting with the situation lol
davievtec
I think we would get along like a house on fire..... Maybe not the best choice of words ;)
Lol yeah our subaru build would consist of a smashed up dash and burned seats with a melted engine mount because it didnt fit lol
davievtec
So you got the one's I sent then Jay :D
