U.K. Or JDM widetrack??
Need some pro's and con's to uk or import widetrack models pls??!!🙏🙏🙏
What does widetrack mean ive always wondered that?
Also twinscroll
Plus I think it is usually more expensive to insure an import...
Widetrack is a late 2005 blob eye model which started using the hawkeye chassis but blob eye shell and engine(uk model)
Twinscroll is a type of turbo set up that splits the exhaust in to two feeds instead of the one. Quicker spool as a result. 0c3acc9c757bbf624c1da9f32646b999.jpg
And the track is 10mm wider over standard models
Jdm all the way better spec lower mileage rust free underneath, slightly more to insure but
Normal Impreza with 5mm spacers on each side? Lol
  • 4 weeks later...
Can anyone also let me know the whiteline rear arb 24mm part number that fits the gdb jdm widetrack?
whats the difference as I thought the one rear arb would fit all
Insurance and parts no difference in cost in reliaty. TYpical myth dealers used to say to try to get you to buy a uk car rather than import.
Other than the burble the JDM is a better option
