Few bits arrived today, just trying to fit them while the boss isn't around [emoji51]
  • Views 1.1m
MOT booked for 20th June [emoji16]
Bonnet has come, looks in good nick, just a few minor stone chips to sort out, happy days,
just need get it on now, easy to fit?
Look's better certainly stands out from the alloy :)
I was quite surprised how much bigger they are than the subaru 4 pots and even more surprised that I had to run the 3 mm spacers make my wide offset rims fit.
The pic's a bit rubbish as by the time I finished fitting them it was getting a bit dark so I had to enhance the pic on my phone so you could see it properly.
They look massive! Very beastly :)
Installed brace and rather randomly it's pushed the rear parcel shelf mounts out buy 2or 3mm
Sti badge turned up for my spliter so when I refurb it I wi have a new badge.
Still don't have the car back yet thought and the misses is getting grumpy about the alloys in the living room. Only a week to go.
I make Films and Website for people
2 new rubber boots fitted to the car this morning on the rears [emoji3]
Take your time, have you got any add a fuses ?
Hardest part will be getting through the firewall and putting the sender adaptors in the top of the block, what you got volts, boost, oil pressure & temp ?
Where are you going for the top of block behind the alternator or under the topmount ?
I went behind the i/c as couldn't be arsed to move the alternator, plus it gives a slightly better reading for temp as that gets the hottest, but less accurate for oil pressure, but if it reads lower I think it gives me more of as fail safe, boost easy,voltage I guess will be taken off the electrical feed anyway ? Have you got the adaptor and extender bit for the new senders to screw into ?
All the bits are in the box how ever you will need a few additional items,
This
http://www.scoobyparts.com/oil-pressure-oil-temp-gauge-fitting-kit-pink
And this is a good idea saves having to chop loads of wires
http://www.amazon.co.uk/Add-A-Circuit-Fuse-Holder-Standard-20amp/dp/1550063146
This is location of where sender lives behind the i/c
This
I'm confused. If it's all in the box what are the extra bits for? First time doing a gauge fitting so forgive my naivety.
EBay has them for a but cheaper too
Tossers ! What did they want for you to shell out 600 notes on a set of defi's ? I've had no problems using mine so far,
