So, after fixing the leather in place with contact adhesive ( https://www.mitre10.co.nz/shop/ados-f2-multipurpose-contact-adhesive-75ml-honey/p/370182 - which is what I should have done in the first place :P ), armrest is reassembled...
All that remained was to install it into the car.
Lowered position...
Elevated...
Raised...
All in all, a pretty straightforward DIY job with a pleasing result. It's the sort of mod that just about anyone could do and simply requires a  cross head screwdriver, contact adhesive, a sharp knife and some cushion foam. Though it would have been a lot easier if Subaru fitted it in the first place :rolleyes:
  • Views 1.1m
Great job and looks well good 😊
Im having lots of fun 70ec7709d133108b42704342e0f24d6b.jpgcbe4355f793ad2951a53c25a95a38fa2.jpg
On 2/23/2014 at 0:36 PM, antlockyer said:
Tried to mop up the mess the leaking radiator has caused and tried to find a part number for a JDM Forester rad.
Had the same issue :( i replaced with a Misimoto Rad and can say it has been perfect. Ill see if i can dig out the receipt and part number.
Head switch of my ej20g to a ej205 block
At least you can recoup some funds by selling the old closed deck block on . Cos if it's on the original bores and in fairly good nick they go for a minimum of £300 just for the block halves [emoji6]
My plan is to eventually turn that in to a bit of an animal its just the crank that has gone
Fitted some led side lights today.
Drove to work...   quietly 😇
Drove home...   quietly 😇
Can you guess where this is going?
A very loud exhaust system?? :D
Drove to work, quietly.
Drove to the garage quietly.
Drove home with a tyrannosaurus in the boot! 😊
(Stainless axle back, muffler delete)
There's absolutely no doubt it's a Scooby now. Rumbles at tick, roars like a thing possessed at wot.
I'll let you know how it sounds at cruising speed later, off to Welshland tomorrow night, so will have a chance to test thoroughly.
Engine went back in today get her back up and running tomorrow
Washed it, then a quick run out to dry the brakes.
Took the day off to oversee day 1 of 3 of log burner installation, only for them to turn up this morning to tell me I needed scaffolding up for them to be able to fit the external chimney work. !Removed! man who quoted us didn't spot it, the dumb !Removed!. Now booked for thu next week.
Meanwhile my garage is full of logs [emoji849]
What kind of burner you gone for dave & what heat output does it give ? Reason I ask is were looking but it's a minefield 😂
We've gone for one called an Ecoburn 5 plus widescreen. It's a relatively new 5kw unit for a room that's 4m by 4m
🤔 contemporary or more 'rustic' ? I shall Google!
We only need a small one but needs to be defra approved etc biggest ball ache is finding someone with reasonable prices to re line the chimney. Cheapest ball park figures are around 1k at the mo.
It's more contemporary than rustic mate
Widescreen? Does it also have WiFi and able to connect to Netflix? :bag:
I'm assuming the widescreen is the lovely window so you can see the logs :D
Yep, the latest i7 processor too and Bluetooth [emoji14]
Dropped her off at the dyno. Not the most ideal situation as I'd rather be there for it. Got offered Saturday work and being self employed with 10 days off for Xmas had to take the work. Gave her a health check last night and a quick blitz this morning so all rosey. Garage is recommended around here too.
Where did she go ?
Place local to me called Hayes engineering. http://www.hayesdynotech.co.uk
Seem to specialise more so in evos but a few local guys have used his dyno.
Ahh nice remap ? Or just a power run ?
