Getting a Gauge set up for Christmas!
So I'm getting 3 gauges and decided to go with the pro sport evo brand. There are a lot of options to consider and i would just like peoples opinions on which i should go for. There is all these to choose from:
.boost psi
.boost bar
.oil pressure
.oil temperature
.water temperature
.fuel pressure
.air/fuel ratio ( narrowband )
.voltage
so which three should i go for?
thanks
Boost, oil temp and oil pressure would be my 3!
I'm goin for one o them 4 in 1 gauges, boost, oil temp, oil press and I think volts, only really interested in the first 3
can you please explain the difference between boost psi and boost bar as I'm not sure on which to get
I'll just copy and paste,
1 Bar = 14.5037738 Psi. Bar is the atmospheric pressure at the sea level. Psi is 1 pound of force per square inch.
Personally I like to use bar measurement as easier to read.
I'd go for bar
Sent from my LAUDE S500 using Tapatalk
I always go psi, why am I always in the minority....... Lol
Why so mr ghost ? I like to see mine reading an exact psi as apposed to trying to convert what it's showing into psi, am I missing summat
I'm the same but opposite. Can't be trying to maths the psi to bar each time.
I thinks it's all personal preference. Much like Fahrenheit and Celsius. They both tell you what it is just different scaling. You could argue psi is more accurate because it uses a broader scale.
i always go Celsius ............................. I know what's comin ........ Lol
Oil pressure (so if you get a leak you know early enough)
Oil temp (so you know it's warm enough to use boost )
Egt or afr (so you know it's not leaning off due to a intake leak)
Boost can help diagnose leaks and overboost but otherwise it just looks pretty
And I prefer bar but that's only a personal preference
i have 4 in my cars,glad i did with the last blobeye i had,i have
boost -bar
oil pressure
oil temp
and water temp which saved my blob as my normal temp gauge was reading normal temp but i noticed the water temp gauge was gradually going up so pulled over and had a look,my radiator hose had got a little hole in and all coolant was quirting out,i think by time my normal temp gauge would have noticed it would have done head gasket,so i allways get water temp gauge as well now.
i had 5 in my 1st hatch i had volts as well but i do like lots gauges so i no whats happening :biggrin:
I started with a cheap depo 4 in 1 gauge. Boost /oil pressure /oil temp /volts as it was only £100 and I thought I'd upgrade it at a later date.
2 scoobs , 2 engines ,2 gearboxes and 5 yrs later the depo is still working fine lol .
But I do now run a apexi fc ecu which monitors everything except afr on the hand controller .
A apexi avcr which monitors throttle position, revs ,boost and injector induity.
3 lamco v1 sti gauges
Depo 4 in 1
And a road angel .
So I've gone from 1 discreet compact gauge to looking like a airplane cockpit [emoji23]
Looking very nice 👍🏻 What pedals you got there? Mine are just boring black ones
I used to have a set of stainless steel and pink newage sti ones which were easy to fit . (I gave them to stants).
The silver and black ones in that pic were off a spec c but I think newage wrx's use the same , i bought them cos they match my scoobs colour better .
But in that pic I still had the sti newage ss and pink throttle peddle [emoji55]
Currently it has the silver and black spec c foot rest ,clutch and brake peddle with the original throttle peddle
As although its tweeking my ocd [emoji33] ,you have to remove the complete throttle peddle assembly to fit the matching throttle peddle. ..... so I keep putting it off [emoji23]
Cheers for the help going to go ahead and order now :)
