Owen369 Posted September 6, 2016 Author Posted September 6, 2016 Dont tempt me [emoji85] subaru taking big funds. RCM any good going to order all bits after work and go with the forge [emoji106]head guy phone is off so not looking good there. Sent from my iphone using Tapatalk
Tidgy Posted September 6, 2016 Posted September 6, 2016 Expensive for what it is but there's worse out there
savage bulldogs Posted September 6, 2016 Posted September 6, 2016 I've found that most things rcm are expensive but very good quality. I was lucky enough to get some cossie headgaskets for £100 off a rally engine builder . Bought arp headstuds, acl shells ,new block bolts ,timing pulley set and full gasket kit from import car parts If it's not broke .....upgrade it 😊
Mr B Posted September 6, 2016 Posted September 6, 2016 Yeh they are good but not really need if not funding a big hp build. cosworth are good and if could get a price same as savage would be worth it otherwise cometic would be fine, ICP do cometic individual or as part of complete head seal/gasket set (about £220 for set, £90 pair of head-gaskets) they good quality viton coated embossed mls gaskets. Standard head bolts are fine for standard & low tune and as they not excessive stretch torque to yeild can be reused if pass inspection. Lot of myths on fine thread no good but reason they use fine thread is it doesn't work loose easily, also fine thread creates more load for same torque over a coarse thread so something be aware of when choosing fastener spec & torque. Proper fitted oem bolts on quality smooth finished heads/block work well,arp stud set around £175 and does allow more clamping torque over standard but not a lot & stud length in block is not best . rcm do some good stud kits when going serious, if going do studs do 12mm - RCM 14/12mm studs get my vote, good design but not cheap and needs block machining. If you not aiming go full out don't waste money on expensive HG or head studs, use it towards good forge pistons & good machine work & quality gaskets. No point spending £160 on head gaskets good for 600hp but running standard rods. Balance all parts so budget evenly spread giving balanced quality/power handling & keeping you well within the budget . 1
Piggysniffer Posted September 6, 2016 Posted September 6, 2016 And if this head guy is a pain to get hold of now, just think how bad it could be if something isn't right and then you can't get hold of him, that will drive you insane !!! as I'm having that problem at the mo, so maybe think about that
Owen369 Posted September 6, 2016 Author Posted September 6, 2016 Right!!!! Feel like im getting somewere now finally. Ordered an should be here for friday. Rcm head gaskets 1.1mm Forged mahle pistons Standard head bolts Dayco timing belt Spark plugs Oil filter Acl main an rod shells Also got a full gasket kit on the way Have had few messages with the head guy says they are at the machine shop being skimmed before he sends them and he will let me know soon as. So things are getting sorted [emoji106][emoji41][emoji529] Sent from my iphone using Tapatalk 3
savage bulldogs Posted September 6, 2016 Posted September 6, 2016 Happy dayz . I'd suggest to get some three bond liquid gasket sealer for the block halves and sump .As cheaper stuff is known not to last . If they're not included in the full gasket set , turbo outlet ,up pipe and header oe gaskets. Dunno if you want to go the whole hog and get timing idlers and tensioner too [emoji6] If it's not broke .....upgrade it 😊
Jay762 Posted September 6, 2016 Posted September 6, 2016 second the 3 bond gasket sealant - have found over years doing bike engines the cheaper stuff just does not work
Jay762 Posted September 6, 2016 Posted September 6, 2016 Dont know if you need it but I have a brand new coolant pump purchased in error from ICP
Owen369 Posted September 6, 2016 Author Posted September 6, 2016 How much would you want for the water pump posted to wolverhampton area Jay762? Going to order some of that sealent now. Tensioner and all that stuff was done 4,000 miles ago and is mint. Many thanks for info lads [emoji108] Sent from my iphone using Tapatalk
Jay762 Posted September 6, 2016 Posted September 6, 2016 Sorry - slight mistake not ICP (had all the tensioners and belt from them) it is this one... http://www.jp4mance.co.uk/products/1/Subaru/_/3206/ £50 and its yours - also I am now local to you (K'Ford) so collection / drop off may be an option?
Owen369 Posted September 6, 2016 Author Posted September 6, 2016 £40 and ill take it off your hands? mine seems fine but never know let me know contact details will meet you anywere in kford[emoji106] Sent from my iphone using Tapatalk 1
Owen369 Posted September 10, 2016 Author Posted September 10, 2016 UPDATE. Bits arrived just waiting on heads now. Been cleaning block and all bits Sent from my iphone using Tapatalk 3
Owen369 Posted September 11, 2016 Author Posted September 11, 2016 Lend me those rods please Tidgy? Very nice [emoji108] got some pictures of my heads finally [emoji106] Sent from my iphone using Tapatalk 1
Owen369 Posted September 12, 2016 Author Posted September 12, 2016 Gutted [emoji85][emoji23]. Starting to build engine back up today anyone point me in right direction for the torque specs on bottom end stuff? Please [emoji120] Sent from my iphone using Tapatalk
savage bulldogs Posted September 12, 2016 Posted September 12, 2016 Dunno if your model is on there but here's a few free pdf files that I used for my classic build . http://ken-gilbert.com/impreza-manuals If it's not broke .....upgrade it 😊 1
Owen369 Posted September 12, 2016 Author Posted September 12, 2016 Many thanks [emoji106] got them [emoji108] Sent from my iphone using Tapatalk
Mr B Posted September 13, 2016 Posted September 13, 2016 SFSM > http://jdmfsm.info/Auto/Japan/Subaru/Impreza/ Make sure cleaned block proper & check the block restrictor gallery to head EXTRA carefully. Also check cams & caps on sourced heads plus all valve collets look seated correct & valve ports for cracks & seats for condition. 1
Owen369 Posted September 13, 2016 Author Posted September 13, 2016 Getting somewere [emoji106]what oil do you all recommend? Got to get some good stuff tomorrow Sent from my iphone using Tapatalk
Mr B Posted September 14, 2016 Posted September 14, 2016 For initial break in you want use a mineral oil. Rings will not bed in on a full synthetic, Were bores cross hatch honed. Get 2 or 3 oil filters and dump oil after first 100 miles and check for unwanted debris, cut filter open too . 2
Owen369 Posted September 14, 2016 Author Posted September 14, 2016 Honed bores yes. Was going to get a cheap oil to wash though first [emoji106] then a good fully synthetic oil and filter change like you say. What oil you run fully synthetic? As in 5w40? Ect Sent from my iphone using Tapatalk
Owen369 Posted September 14, 2016 Author Posted September 14, 2016 Got magnetic sump plug to [emoji106] Sent from my iphone using Tapatalk
Register a new accountSign in
