Added some 'areo' parts [emoji23]
  • Views 1m
Tidy job that mate [emoji23]
tried plasti dip,
installed a red hazard button,
sold my sport bonnet,
cleaned and filled up
Had my car serviced today... done 12k miles now since buying my car in September 2014! Time flies when you're having fun! Desperately needs some new brake discs tho... I'm thinking a full black diamond kit for £410?
My first plasti dip attempt not perfect but just peels off so if i fancy re doing i can going to do around the radio when its abit less windy
Started to peel as i was rough getting the gear knob sock back on [emoji53]
Nice job not tried doing it myself but the finish does look spot on.
i think the black looks alot better, my silvery bits were starting to fade so thought id give it a whirl,
I usually get the rattle cans out for the silver bits but doesn't look bad on the picture [emoji106]
Finally got it to the jet wash and done a rubbish job of it haha still most of the dirt gone but needs a proper wash really.
Also booked in to finally get my exhaust finished not till end of Jan but still can not wait for it to be finished.
Started to think fitting the avcr would be a good idea today [emoji41]
Had another idea to have a few early beers while doing some research on how to wire it in [emoji39]
3 hrs and 7 beers and a couple of jd's later
This little lot is frying my brains and will be going back in the box until the new year [emoji23]
Have a goodn fellas [emoji482] [emoji322]
If it's not broke .....upgrade it
At least I think I've sussed how to plumb it in now [emoji4] but that big bit of paper with covered in squiggles and bubbles is the "quick start" guide when setting it up [emoji15]
the school boy error of being too !Removed! to drive didn't help with the productivity this afternoon [emoji4]
As I need to do a run in each gear so it can learn the differences in vacuum under different loads ,so it can then duplicate the same boost targets/curve in every gear by itself .
Well once I sober up enough to decipher the "quick start " bubble code
Happy new year to you amazing !Removed! [emoji12] [emoji106]
I just ripped out my eculabs. I like the functions and it is very very good for the money ... But what I'm planning with the car I need to physically see stuff so
Apexi back in ! Base map loaded
Mate coming sat with datalogit to copy my old map , and change turbo over , while I delete the dump valve and measure for a harness bar
Oops forgot I had just driv thru a bust water main and cut the turbo in jesus Christ it's scary sideways thru a 30mph limit.
Happy new year too ya all ☺
All the best folks and may all your scoobies be fast and reliable [emoji106]
Just bought myself a cat pipe to remove the third cat in my exhaust.... oh and Happy New Year! I'm stuck at work until 7AM, the joys!!
Happy new year peeps
just telling myself to get up off my a** and go change the oil in my rear diff,well whats left in it as most has leaked out on the drive.
Hanging out my 8rse [emoji87]
