First timer. Hawkeye blew up on way home
Ooooh **** ! Fingers crossed mate but that coulda been why the engine let go the first time ? You mighta caught it in time before serious damage, defo keep an eye on the turbo now as that woulda suffered if oil pressure low, maybe that's why you had hesitation too as it probs couldn't run the avcs properly
  • Replies 221
  • Views 22.1k
  • Right!!!! Feel like im getting somewere now finally. Ordered an should be here for friday. Rcm head gaskets 1.1mm Forged mahle pistons Standard head bolts Dayco timing belt Spark plugs
  • UPDATE. Bits arrived just waiting on heads now. Been cleaning block and all bits Sent from my iPhone using Tapatalk
  • UPDATEEEE Got oil pump on 11mm one oil pressure now 1.2bar lowest at 100c oil temp. Hessantness has gone. Did find 1 small boost pipe half off have secured it. Timing was a nightmare to do in the
Hope you've caught it early enough that it's not done any damage .
Do you know anyone who could fix the damage and weld a brace or fish plate in to strengthen it at the same time ?
Might be a better option than buying/ waiting for a standard replacement.
I just replaced mine from "import car parts", changed the oem for an oem, mine was fine but I needed to rule it out of the equation, so while had sump off thought may as well change it, will probs end up getting a killer b one at some point if I've not burned the car lol
Anyone know were to get a killer b one from next day delivery uk stock like? Going to order a new oem tomorrow morning otherwise family member can weld braze ally weld ect anyone modded one? The pipe was sweet when fitted sure of it i cleaned it fitted new oring ect sure i would of spotted it [emoji25] oil pressure was showing 80psi at 5000rpm rev so hopefully no damage
Could try giving Alyn @ Asperformance a bell, he might have a aftermarket oil pick up in stock and dispatches fast .
Alyn +441914103770
The "fixing / strengthening the old 1 was just a idea , as I don't know much about the 2.5 pick up. I just thought if it's a weak point , why not upgrade it to rule it out .
My original 2ltr oil pick up is nearly 23yrs old and still keeps up with my rcm oil pump fine .
I wouldn't waste over £150 in the killer b one, it the other extreme and totally over engineered & over priced .
I wouldn't repair yours but indeed you could.
What we do is cut some 1.5mm walled tube in half and braze to flange and pipe covering the weak joint area then add a 1.8mm tapered gusset from flange edge to past first bend in pipe & braze that on . another gusset on pick-up filter end goes up and feeds into top gusset. we change flange bolts to 12.9 allen sockets as easier fit with reduced room of gusset & welds near flange (also add drop of threadlock on them). Windage baffle plates quite good for these too especially if likely do some track or do speedy road work on twisty b roads.
material cost isn't £5 for oil pipe & result is several times stronger than plain oem .
Money best spent on a good oil pressure gauge with memory & settable low pressure warning .
Ended up with new oem one fitted it tested oil pressure cold start up is 80psi
Warm idle is 30psi
And as soon as you rev goes to 90psi
Pressures sound all good? Going to order some gauges today and a pod still dont trust the car [emoji85]
Also very hesitant an a little jerky is it just my driving being use to dirty dieselsss [emoji85]
wants a good check over & run on rollers really, loads of minor things cause poor running from det sensor, afm, simple air leak etc .
I expect stress from removal & refitting finished the old oil pipe off as if had been running long like that mains would of been shot.
oil pressure seems about right, oil pressure, boost & wideband are 3 must have gauges really .
Hopefully just simple niggles and all will be good .
Fingers crossed mr b fingers toes and everything inbeetween. Can not thank you enough for all the advice an guidance. Can you suggest anywere local to me (West Midlands) to get it in rollers. Yes took a bit of messing about to get sump off jacked engine up to refit [emoji106] looking at prosport gauges as we speak want to order from shop that got in stock an will supply the defi pod also.
I have only found two wheel rollers local to us - possibly looking at Telford (Severn Valley Motorsport), Cheltenham (Litchfield), Warwick (TDR)
Got some prosport steepers on the way tomorrow put my mind at rest on this oil business. I have put a silcon covered inlet pipe to the turbo on when rebuilt engine would that make it hessant and jerky as not mapped for it maybe? Top man jay762 will get on it going to have to get it on rollers soon like mrb says check all out properly[emoji106]
Good chance that the unmapped bigger turbo inlet pipe is causing running issues . As a friend fitted one to his bug sti and it brought up a code with the eml light.
Once mapped in it was fine [emoji6]
Choose your mapper very wisely !!
Just been out put 40 quid fuel in gave it a run through up to 4-5000rpm. Feels a little better. Were you get yours done piggysniffer?
There is a specific thread on the unfortunate situation PS has found himself in - shall we just leave that there - suffice it to say TDR in Warwick has received some recent positive feedback. They also do just straight pulls for diagnostics not mapping which may be useful?
I couldn't have said it better myself 😉
Weres the thread have had a search but couldn't find it. Will google them now doesn'tseem to far away.
Latest on the subject
Just this minute got the gauges in very dark will take a picture tomorrow. Oil pressure reading 1.5 bar on tick over at the lowest about 21psi that seem ok or low still paranoid about oil ect. Car running better touch wood after blast out last nite and tank of fuel also. dont know if that helped ive only put in high octane. Not had time to ring about the dyno yet
6 bar pressure when cold and when rev or drive not got the oil temp sensor in yet thats a tonight job. 1.5 bar was at idle after a drive round the block at cruise speed
One of the most nail biting threads since I joined, been on the edge of my seat towards the end 😜 Fingers crossed mate
You aint joking piggysniffer nightmaree its been. i got everything crossed hope it all good now 1.5bar lowest ive seen today also. Mudflaps ordered stop sides gettin covered with s**t off the road [emoji106]
Once again thanks to all for the advice and help along the way
