2.5 inserted short engine
5 hours ago, Piggysniffer said:
Yer, wife not cool at all, didn't even ask what money was for, so have asked me ma lol. Will know one way or the other shortly
The worst. Women just don't understand!
  • Replies 69
  • Views 8.3k
  • Piggysniffer
    Piggysniffer
    Had a good chat with graham (nice man) and I will be picking the offending article up next Saturday from "group b Motorsport" 🙂
  • this is funny - I am getting to the point of checking to see what new threads @Piggysniffer has started every morning - they appear to follow a hilarious trend
  • happy hector
    happy hector
    Thanks for that. Alyn at AS Performance did the inserts vapour blat and ultrasonic cleaning. Supplied and tapped for 14mm studs. Hammond at Deeside did the rebore and hone. Crank from Subaru
What have I done to cause such grief and turmoil? I'm scared to turn the news on 'chichester murderer in Subaru slaughterhouse '.
For a counselling service try 07934711909
Nice one 👍🏻 Sounds like a great deal bet you can't wait 😊
I am more than mildly exited tbh, I think that's taking the edge off of the 10hr round trip lol
I love taking my car on road trips it's just fuel that kills me haha. It's such a good feeling picking up parts.
So, next things needed
clutch kit
injectors
heads (well at least the left hand side)
turbo
killer B oil pickup tube
maybe a sump
delete tgv
cam belt kit
left avcs pulley
to start with 😆
Edit:-
turbo back exhaust
headers ?
Just worked it out fuel wise, I've worked it on 28mpg (maybe too optimistic ?) over 500 miles, I think worked out at 81 litres, bout £100, sounds to little, gonna have another check
2 minutes ago, Scoobyghost said:
What's up with the head and avcs?
The piston took a crap and stuck little bits of debris in the head, and  I can watch the avcs solenoid chasing the actual pulley trying to keep the advance steady, so probs leaky seals in pulley (bought car with bad piston)
Nice shopping list you've got there. Is the old one dead?
I used to get around 30 mpg on long slow runs but now it's more like 20. But I smile the whole time 😃 Except when I pay at shell 😂
Same one that was mapped?
Get in there 👍, like the look of that shopping list aswell, itl be some beastie when you get it all together :backofnet:
Yes mate, honed bore, bought set of second hand std pistons and stuck one in, cleaned head up fine, (but still would not put it on this new bottom end I'm getting) did valve gaps and put it back together, told this to mr dynamix at the time
No mate still soldiering on valiantly lol, are you all tuned n built and running big numbers, I was thinking 350bhp but I'm erring
more towards 400 now tbh, turbo is gonna be the thing there methinks
Spose I will want a turbo that can run 400 then run it at 375/380 ?
That's the fun part I love choosing new parts all these little boxes turning up for me feels great haha
clutch kit
injectors
turbo
maybe a sump
delete tgv
cam belt kit
left avcs pulley
to start with 😆
Edit:-
turbo back exhaust
headers ?
Thats a hellva xmas shopping list , hope santas got a leggy estate ..... cos he ain't fitting that lot in a sleigh [emoji39]
Seeing as you're writing a list ,i might as well add a few bits too .
You'd get better power from sti cams /heads (so if you're gonna buy some heads give that some thought)
Brakes to reign in the extra ponies ?
6 speed once its run in and has a big turbo ?
Fmic pending on target power?
Id ask the engine builder what size head gaskets are required for both the wrx or sti head chambers , as i dont know if the chamber sizes differ between the two models . If they've built the bottom end they'll probably already know the answer and it will save a fair bit research on your behalf[emoji6]
Also there's a good chance the piston "bowl " in aftermarket pistons will be different from oe spec, so you'd probably need a different size headgasket to reach the ideal compression ratio (even if you use your old heads ).
3 hours ago, savage bulldogs said:
Thats a hellva xmas shopping list , hope santas got a leggy estate ..... cos he ain't fitting that lot in a sleigh emoji39.png
Id ask the engine builder what size head gaskets are required for both the wrx or sti head chambers , as i dont know if the chamber sizes differ between the two models . If they've built the bottom end they'll probably already know the answer and it will save a fair bit research on your behalfemoji6.png
Yeah, I think I'm in for the long haul with this one, it's gonna take more than one Xmas list to get this done, but I want it right, I don't see myself doing a 6 speed conversion tbh, and I don't want any more than 400bhp, so hope a 5 speed can handle that ? I don't want to have the engine anywhere near its limit as I want it to last so 400 on a 500 build should be good I hope , I don't think I'm gonna need sti heads for that, I don't know if I'm gonna need new headers either, I will have to find these things out, brakes is defo a good idea tho 😳
