First time buyer
as long as you’ve put 4.5L in it crack open a cold wan and chill you’ll get used to all this in time mate 👍
  • Replies 549
  • Views 54k
Haha did enough of that last night rough as a bita toast today like, dont recommend that with little monsters runnin about😫.
Well that escalated quick didnt Haha, I've got to be holding some forum record hear for the most questions surely
!Removed! I’ve ma two to watch the morra so I’ll know exactly how ya feel 😂🤣 def a record I’d reckon mate lol but if you don’t ask you don’t know
mines 16 now so she is just expensive and only the one. Taxi service now too. Sounds like you have multiple young ones ouch.
SCANNER!!!!!??????? I am all in now taking this journey with you. You must post back and any cure or these 200 replies are meaningless
1 hour ago, Siluro said:
SCANNER!!!!!???????
Haha 😂 pmsl I vision you shouting this in his letterbox, good point but any news Daryl?
Haha good to know I need all the help.i can get! So the scanners finally here? Got the day off work today so gonna get on it shortly, I've not used one of these suckers before hope they're easy, from what I can gather you plug it in an switch ignition on but not to turn engine over?
It plugs in your obd port which is under your steering wheel column, you can read the codes with engine running but all you really need to do is turn ignition on and the scanner tells you the rest 👍👍
Ran through everything as the instructions said but no codes ? But check engine lights still on ? Wtf?
Checked it with engine running and just with ignition on
Just read it can be from !Removed! code readers😭 software error or somethin
Do you have an option to clear codes? I guess not if there aren't any. Is there any pending codes stored. These are codes that have been triggered but not enough to put the check engine light on?
Checking now dont know if I can see pending codes on this reader but I'll check now
Nah nothing like that on it jobs fooked
Cant believe my luck honestly wait all this time for the thing an it cant even read code now I'm gonna have to pay to have it done 🤣🤣🤣🤣🤣
Somethin I thought was strange it wouldn't tell me the vin number either an when I went on a menu for like the egr an fuel an bits like that it was just n/a
Bummer. I think Halfords will read them for a cost.
Got a garage just down the st thatll do it probably 30 40 quid
Does it mean it's a bad fault.if that wont read.it?
TBH no idea but I bet it is just the reader.
Well shes in garage now so soon find out
Check your fuses. The OBD port can share the same fuse as the cigarette lighter for example.
