First time buyer
1 minute ago, Siluro said:
Check your fuses. The OBD port can share the same fuse as the cigarette lighter.
Would it.still register a scan?
  • Replies 549
  • Views 54k
If the port is not active then no it would not scan. It would do nothing.
Hopefully they'll check that if they cant get a reading
I am hoping no news is good news and you are out blasting down the lanes enjoying it.
No news for me either they're taking their time just said theyd be able to fit it.in at some point today
That’s weird that scanner didn’t work mate it’s a cheap amazon number I have and it works fine. You didn’t say to them I’m not in a hurry did you lol? That means to a mechanic when I can be arsed lol
Just heard back from the garage apparently its blowing from a few different holes in the exhaust an the part from the dealer is roughly a 1000, gonna price up some aftermarket bits for me tommorow devastated...
Well the money you have saved from not buying a CAI that would make no or little power difference. Exhaust parts can give you more hp and make the turbo spool quicker. Also sounds better too. Good luck
Cai? Wonder what difference the after market parts gonna be compared to Subaru?
Cold Air intake
Thats pants mate, did they tell you what parts of the exhaust are shagged although at that price i'm assuming its the cat 👍
Ah right cai yeah got ya wasnt planning on getting that anytime soon though lol. Yeah it's the cat section mate, he said theirs question Mark's on the up Pipe aswell. This is gonna cripple my savings like. Any of you lads know if the aftermarket price will be much cheaper if any?
Would yous let a normal but decent garage do this?
You could just get replacements from a breaker’s mate if your just staying standard the now will save you a bomb. Did they tell you what the code was?
If staying standard as RossCosm says find one a breakers if time allows. If going aftermarket (for more power) then it gets expensive due to the map being needed. Need to plan this type of stuff but of course that not so easy sometimes. How comes it took all day to see some holes?
If you trust them mate then it should be ok as it's just a couple bits of exhaust but you'll have to tell them to use genuine subaru gaskets which are only a few quid from importcarparts.co.uk thats where a few of us on here get oem parts from at a decent price 👍
Exhaust is not that tricky but i would take Stuartie advise.
I wouldn't even know where to start with a scrappy I've struggled for stuff recently out of scrappys, an that was for a golf, I know its gonna be expensive but they do a monthly pay plan so thatll help, an I know that's one thing right, I'll go ahead with that then mate cheers again lads, I'll get them to get the genuine gaskets aswell I will order those will they fit any exhaust the garage gets?
Just tried to find then on import car parts apparently they dont have any
I’ve used Mb developments for used Scooby parts before and they are top notch mate they on Facebook but if you don’t have Facebook just type them in to google, the picture is obviously a kit but they do individual gaskets aswell mate
Top notch support. Good stuff
Thanks rossco legend, I guess I just need to find out exactly which gaskets I need to get first wonder how much the up pipe would be to get done aswell are they dear? Is their a kit I can get that will def have the gaskets I need ? Knowing what I've told yas?
They do a kit specifically for fitting an uppipe mate. An Sti uppipe used is like £60, Brand new decat uppipes are like £150-£200 ish. The labour because of where it is will not be cheap that is if your mechanic doesn’t throw a hissy fit cause you want to supply your own parts I’ve had this loads in the past til I found the guy I use now. I’d send your scan tool back and say money please buy one that will work and clear the code then enjoy your car for a while while you save for a few bits and a map. You can probably achieve this with like £500-£600 tops if you go to the right person. Again mate you really need to know what that code is so you don’t pay for a mechanic to guess and just throw a grand down the toilet for the code to come back on the way home. By the sounds of it they have read the code and plan to just throw a new cat at it and hope for the best. I hope this isn’t tainting your enjoyment of your car mate There are so many who have gone through this with Scoobys me included.
I have to agree with rosscom that you need the code to verify a new cat may cure check light.
I'm gonna look into the 2nd hand parts then  that looks like the road to take with this one, I googled mb developments but only seem to have a fb page so found another called 1st choice, waiting to hear from them, I'll call mb today at some point. I'll get the code later aswell he said it was an 02 sensor code it brought up, but said theirs loads of holes in the exhaust so obv it needs doin. That would trigger a code wouldn't it?
