david1972 Posted August 9, 2017 Posted August 9, 2017 Washed the car, ahead of the show I'm going to this weekend [emoji41] Sent from my iphone using Tapatalk
savage bulldogs Posted August 9, 2017 Posted August 9, 2017 Told the mrs I needed to find a Shell garage as we only had just over half a tank and the scoob don't run on anything but v power [emoji6] Seeing as were away on hols in sunny Cornwall , i found 1 on Google maps and plumbed it in on the sat nav then set off to fill her up .... 2.5 hrs later ,via lots of twisties and a "water splash" (fjord) [emoji41] i finally returned grinning like a Cheshire cat with just under half a tank [emoji15] Guess I'd better nip out and brim the tank again tomorrow [emoji23] 5
majik_thighs Posted August 10, 2017 Posted August 10, 2017 Parked outside college at lunchtime..... oops! Sorry, wrong forum.[emoji4] Sent from my SM-G950F using Tapatalk 1
Tidgy Posted August 10, 2017 Posted August 10, 2017 41 minutes ago, majik_thighs said: Parked outside college at lunchtime..... oops! Sorry, wrong forum. Sent from my SM-G950F using Tapatalk out on the pull eh,,,,, hahahahaha 1
savage bulldogs Posted August 10, 2017 Posted August 10, 2017 Had a bit of rough footage with my scoob in sent to me from the set of foreign beggars music video shoot [emoji41] . If the weather's good we'll be shooting part 2 this sunday [emoji6] 4
Beags Posted August 10, 2017 Posted August 10, 2017 Soffened up the coilovers 4 clicks then Drove 370 miles from suffolk to Cornwall. managed to get 310 miles out of a small jdm classic tank [emoji16] Not bad for for a 360 hp car with a boot full of cases and 4 up [emoji41] Admittedly my mapper' s attention to off boost fuelling (not just pub figures) and the UK ratio 6 speed giving me 2750 rpm in 6th at 70mph helped [emoji6] In the hatch I sit at about 2750 rpm at about 80mph although that's the indicated speed , because in the newer 6 speeds don't they have slightly longer ratios as the engine doesn't rev as high I went by the sat nav' s GPS speed readout as my 23yr old mechanical Speedo is a bit out lol . I didn't know they did different uk ratios tbh but know there's at least 3 different jdm ratios (so it makes sense) My 6 speed was out of a 60k 04 plate blobeye uk sti with ppp (so came with the ppp short shift) was lucky enough that it was a full conversion kit including 6 speed fly ,pink box clutch ,slave and starter motor for £1350 delivered [emoji41] did not think the ppp job extended to a short shift. mine is an 08 with ppp. is it easy to see if it has the short shifter. Sent from my SM-J320FN using Tapatalk
savage bulldogs Posted August 10, 2017 Posted August 10, 2017 Soffened up the coilovers 4 clicks then Drove 370 miles from suffolk to Cornwall. managed to get 310 miles out of a small jdm classic tank [emoji16] Not bad for for a 360 hp car with a boot full of cases and 4 up [emoji41] Admittedly my mapper' s attention to off boost fuelling (not just pub figures) and the UK ratio 6 speed giving me 2750 rpm in 6th at 70mph helped [emoji6] In the hatch I sit at about 2750 rpm at about 80mph although that's the indicated speed , because in the newer 6 speeds don't they have slightly longer ratios as the engine doesn't rev as high I went by the sat nav' s GPS speed readout as my 23yr old mechanical Speedo is a bit out lol . I didn't know they did different uk ratios tbh but know there's at least 3 different jdm ratios (so it makes sense) My 6 speed was out of a 60k 04 plate blobeye uk sti with ppp (so came with the ppp short shift) was lucky enough that it was a full conversion kit including 6 speed fly ,pink box clutch ,slave and starter motor for £1350 delivered [emoji41] did not think the ppp job extended to a short shift. mine is an 08 with ppp. is it easy to see if it has the short shifter. Sent from my SM-J320FN using Tapatalk Dunno how much of a visual difference there is but mine's definitely got a shorter "through" than my brvs old bugeye 6 speed and a mates blobeye uk sti
Beags Posted August 10, 2017 Posted August 10, 2017 Soffened up the coilovers 4 clicks then Drove 370 miles from suffolk to Cornwall. managed to get 310 miles out of a small jdm classic tank [emoji16] Not bad for for a 360 hp car with a boot full of cases and 4 up [emoji41] Admittedly my mapper' s attention to off boost fuelling (not just pub figures) and the UK ratio 6 speed giving me 2750 rpm in 6th at 70mph helped [emoji6] In the hatch I sit at about 2750 rpm at about 80mph although that's the indicated speed , because in the newer 6 speeds don't they have slightly longer ratios as the engine doesn't rev as high I went by the sat nav' s GPS speed readout as my 23yr old mechanical Speedo is a bit out lol . I didn't know they did different uk ratios tbh but know there's at least 3 different jdm ratios (so it makes sense) My 6 speed was out of a 60k 04 plate blobeye uk sti with ppp (so came with the ppp short shift) was lucky enough that it was a full conversion kit including 6 speed fly ,pink box clutch ,slave and starter motor for £1350 delivered [emoji41] did not think the ppp job extended to a short shift. mine is an 08 with ppp. is it easy to see if it has the short shifter. Sent from my SM-J320FN using Tapatalk Dunno how much of a visual difference there is but mine's definitely got a shorter "through" than my brvs old bugeye 6 speed and a mates blobeye uk sti leather gaiter looks a bit baggy. so might mean short shifter. Sent from my SM-J320FN using Tapatalk
mattiekane Posted August 10, 2017 Posted August 10, 2017 Got my hks coilovers fitted [emoji41] Proper pictures or it didn't happen Sent from my HTC One M9 using Tapatalk
HawkSTI Posted August 10, 2017 Posted August 10, 2017 1 hour ago, mattiekane said: Proper pictures or it didn't happen. 😂😂 here you go @mattiekane, I even washed it too 😝 Can still be raised or lowered an inch or so either way if needed. 4
Jesse James Posted August 10, 2017 Posted August 10, 2017 More pics mate. Looks very nice indeed Sent from my SM-G935F using Tapatalk
HawkSTI Posted August 10, 2017 Posted August 10, 2017 @Jesse James thank you mate 👍 Ive added loads of pics to my build thread if you want to have a look 👀
Steveuk260.Esq Posted August 10, 2017 Posted August 10, 2017 More pics mate. Looks very nice indeed Sent from my SM-G935F using Tapatalk Definitely more pics looks million times better than mine damnit. Sent from my SM-G900F using Tapatalk
HawkSTI Posted August 10, 2017 Posted August 10, 2017 @steveuk260 thank you very much mate 👍 Ive added loads of pics to my build thread so won't double post them in here as well 😉
Jesse James Posted August 10, 2017 Posted August 10, 2017 @steveuk260 thank you very much mate [emoji106] Ive added loads of pics to my build thread so won't double post them in here as well [emoji6] Have you got a link to it mate Sent from my SM-G935F using Tapatalk
savage bulldogs Posted August 12, 2017 Posted August 12, 2017 Just got back from a hell'va long road trip from suffolk to Cornwall , glad to say my 23yr old scooby ate the miles and didn't use a drop of oil or water [emoji41] The only minor thing I had to do was empty the catch can. Got through a fair bit of v power but did manage 310 miles to the first tank sitting at 70 on the carriage way off boost . Admittedly the mpg went down considerably when i was driving in the twisties but the old girl did put a grin on my face. Might treat her to a wash tomorrow as the country lanes and fjords have made her a bit grubby lol 1
david1972 Posted August 13, 2017 Posted August 13, 2017 Attended the Newcastle car show yesterday with folk from NESOC...great fun, despite the rain. Pics can be found in the show thread. Next up is slammed at druridge bay on bank holiday weekend [emoji41] Sent from my iphone using Tapatalk 1
Pixyflash Posted August 13, 2017 Posted August 13, 2017 Couldn't make up my mind on new wheels, so took the plunge and fitted some 15mm hubcentric spacers, Direnza.
GeoffLeggy Posted August 13, 2017 Posted August 13, 2017 3 minutes ago, Pixyflash said: Couldn't make up my mind on new wheels, so took the plunge and fitted some 15mm hubcentric spacers Looks perfect
savage bulldogs Posted August 16, 2017 Posted August 16, 2017 Well after driving almost 1k miles in the scoob the mrs got in it today ,started on the button ,idled for 5 mins then stalled and wouldn't re start [emoji57] Just turns over with no power to the dash ,fc controller,avcr ,afr gauge or lights . But the parking lights ,stereo,multi gauge ,ciggy lighter all work fine [emoji15] So today i be mostly reading wiring diagrams [emoji52]
Steveuk260.Esq Posted August 17, 2017 Posted August 17, 2017 Well after driving almost 1k miles in the scoob the mrs got in it today ,started on the button ,idled for 5 mins then stalled and wouldn't re start [emoji57] Just turns over with no power to the dash ,fc controller,avcr ,afr gauge or lights . But the parking lights ,stereo,multi gauge ,ciggy lighter all work fine [emoji15] So today i be mostly reading wiring diagrams [emoji52] I assume you checked all fuses with a voltmeter [emoji16] Sent from my SM-G900F using Tapatalk
savage bulldogs Posted August 17, 2017 Posted August 17, 2017 Checked a load of stuff with the multi meter and managed to redneck some power to the ignition fuse [emoji51] ..... and it starts and runs fine with power to everything [emoji41] but dash lights dont come on [emoji57] Hmmm scooby sparky crash course ,anyone [emoji23]
Register a new accountSign in
