Posted
Not exactly today, but I obviously put the new exhaust on the other week and finally gave her a good wash and used the bairn for child labour to hoover it out haha.
YAY! 666 POSTS :D
Posted
Well yesterday now but chopped it in for a new (newer) one.
Did you see what I done?
Came in a blue Scoob, left in a white one
  • Like 3
Posted
Cracked my nur spec, so currently running a cat back straight pipe
Posted
Started playing with the classic, Taking some rust off underside and undersealing as much as possible, only to be greated by rot under the sil covers.....after swearing for a while  changed the rear diff oil while it was up because no chance am I putting the back end on stands till its repaired. The amount of sand and grit etc that has come out from the sill covers is astonishing can only assume the car was owned by a *****. Scrubbed inside the wheel arches after pulling the rubber strips off so much crud in there for such a small place thankfully they weren't rusted up anyway
Knew I shouldn't have trusted an add that said "NO RUST" .... still love it though
Posted
You sausage 🤣🤣🤣
  • Like 2
Posted
Great when a mechanic turns round and says I should change the rear bushes, just after i thickly undersealed the back end lmao , strip down begins :D
Posted
changed my SOC window sticker, its finally weathered about nearly three years, so ive applied a new one
found out my boot release wasn't working, but it was just the little lever on the boot lock had been knocked into the up position
and also found out that i have a wet boot, so must be a leak somewhere, only just noticed it during these heavy rains <---- any ideas?
Posted
Boot lid seal or hole in boot floor?
7 hours ago, Plug said:
do the Feds read this?
Wouldn't put it past them to read this, nosey gits
Posted
Put the car in for an MOT today. Passed that and then went for brake work. Apparently the original threads on the calipers are smaller than the calipers godspeed have supplied. Anyone heard of calipers being imperial thread size or a possible reason?
This could all be garage bull of course. Waiting for a call.
Posted
Got links and roll bar etc back from blasting, 2 bits missing. Working out which body part to take off the guy first
Posted
6 minutes ago, mattiekane said:
Head
That would make their passing too quick
Posted
Aye be he's clearly not using it so probably won't have an effect [emoji23]
  • Haha 1
Register a new account
Sign in
