  1. Tap the 3-dot menu (โ‹ฎ) in the top-right corner of the browser.
Power graphs for reference
Thought it would be a good idea to get a thread going of peoples dyno graphs so if folksย want info on what they can expect from what turbo/engine/mod combo.
Can we please not have comments/general talk in this thread so it's just posts of graph and spec than can be searched for answers.
I've created a chat thread here,ย
ย
If parts arn't off the shelf (turbos are a good example) please add (custom) so its easy to tell.
Mine as a starter,
ย
2.5 Closed deck converted block, mahle pistons, manley rods, ARP headstuds, ACl bearings, Supertech valve kit in V5 heads (none AVCS). Perrin inlet pipe, Front mount intercooler, Perrin induction kit, walbro 400 fuel pump, Nismo 740CC injectors, Syvecs ECU, GT spec Gen 2 headers, 06 UK hawk sti 6 speed gearbox, twin plate competition clutch, Full cobra decat, Garret GT2871 R billet turbo (Custom), 3 port boost solenoid, 4 bar map sensor.
GT2871r%20Graph%20-%20Edit_zpswkyjemds.j
ย
Good thread
GC8 Turbo 2000
TD04 turbo
Cosworth panel filter
Unnamed 3" decat turbo back exhaust
RCM fuel pump
Ecutek licensed remap.
All other parts as standard on turbo 2000 UK spec v6.
2004 Blob WRX
STI top mount
Standard TD04 turbo
Decat up-pipe and centre pipe, prodrive sports cat downpipe
Walbro 255lph fuel pump
Figures are at the wheels
ย
ย
here's mine
2006 Hawk WRX , cosworth filter, full decat, SWRD Colossusย 290lph Fuel Pump ,ย standard td04
open source mapย
Engine tuner built ej257 bottom end ( check my build thread for full spec) standard refurbished sti hatch dual avcs heads . RCM unequal length headers , RCM up pipe , RCM 3" down pipe with decat , standard centre pipe with prodrive 330s back box , cosworth drop in filter , Perrin intake pipe , engine tuner spec Gtx2871 mamba turbo with 650cc injectors and mapped on ecutek software
08 impreza wrx hatchback
VF52 turbo
RCM340 fuel pump
front mountย intercooler
AEMย cold air intake
GFB responce bov
longlife full 3inch decat exhaust
340 fuel pump, fmic, 440 yellows and alcatekย running mafless td04ย
IMG_1643.thumb.JPG.bfc4ae09822f3a9efb8a7
1993 import wrx
Top entry td05
Front mount
440 injectors with parallel fuel lines
Fpr
255 fuel pump
Full de cat blitz nur spec
Started to misfire around 4000 with original coil packs so turned down
Good thread
GC8 Turbo 2000
TD04 turbo
RCM fuel pump
And what happens when your car runs rich:
Before remap in red and after in blue. 285 BHP at the spark plugย :smile:.
2003 2.0 WRX, Pipercross air filter, straight through mid pipe and Prodrive back box.
Good thread
GC8 Turbo 2000
TD04 turbo
RCM fuel pump
95fb249573914bb011fd0131295a34c4.jpg Just a follow up. All healthy again.
Mad how it made exactly the same figure lol
2005 WRX,
prodrive exhaust, and maybe full ppp, but not from factory. I can see prodrive intercooler hoses, unsure about fuel pump so could be standard.
The rest standard as far as I know.
Remapped by engine tuner, Plymouth
285.4 BHP
2002 Subaru forester S Turboย
Standard apart from decat, wrx exhaust cat back, Sti top mounted intercooler and new td04 turbo. ย  Hoping to extend that power figure a little in the future by bigger exhaust, panel filter and or bigger turbo.
ย
Blobeye 2003 WRX
VF35 Turbo
Heatwrapped Decat Uppipe/Decat Downpipe/Straight Through Centre To Vortex Afterburner Backbox (2.5 inch exhaust size)
STI Top Mount Intercooler
Pink 550c Injectors
Forge Recirc Valve
Cosworth Panel Filter
Walbro 255 Fuel Pump
ย
Made 317BHP at 1.4bar Remapped By Area 52 and pops and bangs on the overun.
  • 5 months later...
Oh yes I forgot update , new map with the tmic and new intake calibrated too
Ej257 with gtx2871 see my build thread for more info
ย
  • 8 months later...
Standard Hawkeye WRX no mods. Green Panel filter replaced before tune.
ย
2010 wrx-sย
Unnamed Sports๏ปฟย Cat
Cobra cat back 3โ€ de-resonated
360 lph fuel pump
K&N induction kitย
ย
Ignore the oscillation on the graph, there was a problem with one of the circuit boards causing it on the roller.ย
  • 6 months later...
2011 WRX STI Type UK
Full Decat Downpipe&Centre pipe 3"
Custom Catback 2.5"
Cosworth Panel filter.
Mapped on momentum
light blue lines are a previous power run with only the catback and the factory performance pack.
Pink line is with the above and remap by Duncan Graham.
  • 1 year later...
2007 wrx hawkeye
vf48 , Full Decat Downpipe&Centre pipe 3" headers,uppipe
255 fuel pum,cold air induction kit
ย
ย
08 STI standard internals, ARP bolts, Cosworth HG, Cylinder 4 cooling mod,ย  Cosworth panel filter, standard UEL headers, HKS uppipe, Cobra full stainless turbo back system, standard VF48, standard fuel system, 3 port boost solenoid
Area 52 made a decent job of the first map and TDR only had to do some minor tweaks for the different turbo.
ย
ย
ย
ย
ย
ย
ย
ย
ย
ย
ย
  2. Tap Permissions โ†’ Notifications.
