9 minutes ago, Jay762 said:
Thanks - I have seen various discussions online about how he has tried different diameter tubes / fittings, my concern is taking too much coolant away from where it is being routed to after the head on cylinder 4
The function diagram of the cooling system shows it returns directly to the pump from, the return line. As a plumber to me it's a poor design.
But when it's not installed the coolant flows either through the turbo and back to the reservoir and radiator, or to the heater matrix, and back to the pump
  • Views 1.1m
Do you have a link to the diagram?
He discusses it on a YouTube video called "reverse cooling and how it applies to subarus" its towards the backend of the video, he says it's from the Subaru manual
got you, I will watch the video
Fitted LED DRL’s today (way too bright for night time 😳), wanted to fit LED fog light bulbs as well it’s a shame the body of the actual LED part was too big to fit through the hole of the reflector 😩 Also fitted some cheesy door lamps someone got me from wish, only double sided tape so easy to remove when I got bored of them.
Started the driver's side 😖😪
so much rust
I fitted my Perrin fmic yesterday
b3ecbe7c748c8ab2dfbf2ef690b417c7.jpg&key=4027ce7e2384cbfe0e6e639dd2287db71507abd8d1b8b1fcc9c06d2c69dd1bf1
Fitting my straight through invidia r400 next weekend
so much rust
I feel your pain mate mines are the same but this winter they getting cut out and replaced, going to buy repair panels from that place on facebook and the blacksmiths at work are going to weld them in for me as they'll do a better job of it than myself 👍
Not to put you off but ready for the unseen rot on inner arches and sill. I've hand made all mine so far from 3x2 flat plate
Yeah i have already prepared my self for the hidden tin worm buddy but at least I'll be keeping another classic on the road and it's good to see you're doing the same 👍
@Neil looks like you've got your work "cut out " for you there bud , I ended up scrapping my 1st v3 UK turbo due to tin worm 😏
It looked minor rust from the small 10p sized bubble in the paintwork on one arch but inner arches ,sills ,bumper mounts and strutt tops were non existent 🙄
Check the strutt tops while its stripped, as I didn't realise how bad mine was until i removed the boot liners .
Good luck with it chap
Luckily the strut mounts are in one piece it's JUST 🤔 the inner arches, outer arches, sills, bumper mounts and a bit on the rear panel . It's been off road about 18 month so far, only took it off road for a week to sort a bit of a bubble under paint 😱
23 hours ago, d.. said:
Looking good - watch for rubbing of pipework on the oil filler cap
Put rear tint on my lenses then thought that you need more than 1 person for this job. I cant hold the gun while I stretch out the creases
 Not bad suppose for 1st attempt and on my tod.
Probably either take it to someone or maybe get a hand to put them on so there 100% . It's alright. It's just not 100% she wont come out to play till it's done right !
20190905_200729.thumb.jpg.aef967e78f0fad9fc5ece20461fa8d72.jpgRemove front caliper, stripped the pistons, seals and split the caliper.
I've repainted them black and pink, just waiting on the seal kit for rebuilding.
Looks mint mate.  Might figure how to do mine that must save a few quid . Where bout you from boi.  Anyone from newr dundee / fife.  Im.in newport need scooby help in places 07525406402
I'm in West Yorkshire.
Paint £20, laquer £8 ,new seals front and back £40 (genuine Subaru), Subaru lettering £4
£72
Cheapest refurb I could find was £200 ish
Hardest part is removing the pistons.
I have the gold brembos front and rear as mines a spec C .
It's only one brembo at front I kinda need touched up. Looked like a whens come off at some point scraping it to hellill take a closer pic. I'm DD6 postcode.
CBA doing rear lights so might just get someone to do that for me also.  Hard to get perfect fit eh
Busy weekend for the scooby 😊
Took it to a local retro car meet on friday evening and a local jap car meet this morning.
Unfortunately only took 1 pic of mine and my mates evo ,as we were too busy walking around and chatting 🙄
So here's a few pics I shamelessly screenshoted off the f.b page 😊
Fitted Perrin 2.4” inlet pipe in anticipation for my remap
Some great motors there but not a fan of that supra too much form over function for me - was spoilt when the Top Secret supra was revealed and that tends to be my benchmark
