6 hours ago, matt said:
4" exit looks nice out the back! im after a angled one
a fabricator could adjust an existing backbox to be like that for a lot less than a new one would cost I would think
  • Views 1.1m
20 hours ago, Hudson said:
Ordered a 3" bore Cobra exhaust with a 4" tip from reading good feedback about them and already got a 3" bore de-cat down pipe that will match up with it but still need to order either cobras 200cell cat downpipe or a 100cell cat downpipe from japspeed for mot as currently got the original exhaust system on with an aftermarket backbox welded on but been thrown an engine code recently 'catalyst efficiency below threshold' so either one of the sensors is dead or the cat is - either way I had a new exhaust on the cards for the summer anyway.
You can get the efficiency cel if you have a pre cat/pre sensor leak
I'll try see if can spot any leaks before I strip it all off :)
22 hours ago, Fastboy67 said:
Washer jets on drivers side of mine are quite poor I was thinking of replacing the pump on the water bottle I'll see what works for you bud 😂😂👍👍
I'm hoping mine just has a bit of debris in the nozzle - the pair on the drivers side are fine, as is one of the two on the passenger side. Just need a suitably thin bit of wire to shove in the hole (oo errr)
Brought it out the garage. First time in 3 months! Rear bumper bracket replaced along with the number plate light brackets. Next job, a full service ready for summer, and replace the exhaust.
Washer jets on drivers side of mine are quite poor I was thinking of replacing the pump on the water bottle I'll see what works for you bud [emoji23][emoji23][emoji106][emoji106]
Well it looks like the little metal nozzle had worked itself loose of the connector. Shoved a paper clip into it, pushed it back in / on, and working as normal again now.
Couldn't find where the water was getting into the boot. Rubber seals are ok so will have a better look over weekend.
Noticed sidelight bulb was out. Shut bonnet after windscreen washer fiddling and it came back on [emoji849]
@david1972
Water in the boot is a fairly common problem on blobs, it's either the seals round the light or a grommet but can't remember exactly , best off googling it
Changed the oil this morning, mmm fresh !
spent 45mins washing it :sad:
Got it some new rubber today for the new alloys and book't it in for service and mot at sss on thursday.
Drove to Ikea in Leeds an back listening to that lovely worn out wheel bearing :-/ think it's time to fit the new ones
Fitted new wheels [emoji41]
Well bottom end just gone time to take the engine out again!!!!
On 17 February 2017 at 6:45 PM, JamesJDMwagon said:
So this turned up today 😊 Accumulating parts
Where from, how much 🤔
Set out to fit new wheel bearing on rear. Everything is sized solid so wire brushed it all, sprayed some penetrating oil on and I'll have another go next week end
Washed it and filled it up with momentum. Was a sg Foz turbo there filling up too...owner just stopped and stared as I pulled in, then walked to kiosk to pay staring, then walked back to Foz staring...priceless [emoji2]
Picture?
Only picture i have so far of the car with wheels on as am still fitting breaks.got the front brembos fitted today,hopefully will have time to do the rears tommorow
finally got around to giving her a wash, been meaning to for a few weeks now
then had a go at repairing some scratches in the front headlight using a hairdryer, it was affective with the really shallow scratches so I had a go with a heat gun on the deeper ones. That did not go so well as the headlight now looks like it has a permanent white bird poo on it - doh !:bangin:
Was braking going over a drain cover and heard a rather large knock, hoping it was just the drain or I've broken something. Car didn't feel any different afterwards so hopefully if something has broken, maybe just one of my front drop links (which are needing replaced anyway)
Finally got round to fitting bonnet gas struts, a few silicone hoses buts needs a good clean up.
Niceeee. We need to meet up sometime. Find some nice roads ;)
